Bounce This Along The U.S. Postal service sent out a message to all letter carriers to put a Sheet of Bounce in their uniform pockets to keep yellow-jackets away. Use them all the time when playing baseball and soccer. I use it when I Am working outside. It really works. The insects just veer around you. All this time you've just been putting Bounce in the dryer! 1. It will chase ants away when you lay a sheet near them. It also repels mice. 2. Spread sheets around foundation areas, or in trailers, or cars that are sitting and it keeps mice from entering your vehicle. 3. It takes the odor out of books and photo albums that don't get opened too often. 4. It repels mosquitoes. Tie a sheet of Bounce through a belt loop when outdoors during mosquito season. 5. Eliminate static electricity from your television (or computer) screen. 6. Since Bounce is designed to help eliminate static cling, wipe your television screen with a used sheet of Bounce to keep dust from resettling.. 7. Dissolve soap **** from shower doors. Clean with a sheet of Bounce. 8. To freshen the air in your home - Place an individual sheet of Bounce in a drawer or hang in the closet. 9. Put Bounce sheet in vacuum cleaner. 10. Prevent thread from tangling. Run a threaded needle through a sheet of Bounce before beginning to sew. 11. Prevent musty suitcases. Place an individual sheet of Bounce inside empty luggage before storing. 12. To freshen the air in your car - Place a sheet of Bounce under the front seat. 13. Clean baked-on foods from a cooking pan. Put a sheet in a pan, fill with water, let sit overnight, and sponge clean. The anti-static agent apparently weakens the bond between the food and the pan.. 14. Eliminate odors in wastebaskets. Place a sheet of Bounce at the bottom of the wastebasket. 15. Collect cat hair. Rubbing the area with a sheet of Bounce will magnetically attract all the loose hairs. 16. Eliminate static electricity from Venetian blinds..Wipe the blinds with a sheet of Bounce to prevent dust from resettling. 17. Wipe up sawdust from drilling or sand papering. A used sheet of Bounce will collect sawdust like a tack cloth. 18. Eliminate odors in dirty laundry. Place an individual sheet of Bounce at the bottom of a laundry bag or hamper. 19. Deodorize shoes or sneakers. Place a sheet of Bounce in your shoes or sneakers overnight. 20. Golfers put a Bounce sheet in their back pocket to Keep the bees away. 21. Put a Bounce sheet in your sleeping bag and tent before folding and storing them. It will keep them smelling fresh. 22. Wet a Bounce sheet, hose down your car, and wipe love bugs off easily with the wet Bounce. 23. Put a sheet of Bounce in your suitcase when traveling, it will help keep mites or any other critters out of it. While you are at it, travel with several Bounce sheets and run them up and down your bed linen before getting into bed, it will cause all the critters already in your bed to run. Keep a sheet in your suitcase even after you have unpacked to protect your suitcases from bugs nesting in it. Quick, bounce this on within the next 5 minutes! Nothing will happen if you don't, but your friends will be glad to hear these hints! IN GOD WE TRUST Bounce fabric sheets, keep bugs away?
SOURCE: How to set a static IP address in Windows behind a Linksys Router
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
SOURCE: wireless connection
Check out the IP address is provided Dynamically correctly or not. If it is correct the open
http://10.0.0.1
Go to Status - set ip Dynamically - save.
Now, check the website opening.........
SOURCE: Microsoft Works Please help
Get new stuff you don't have to look through particularly grotty Half-Price Books (though you could use AbeBooks) to obtain relevant manuals! Linux and OpenOffice can do your job; OpenSolaris and one of Sun's office suites can too. Your machine won't be zombified every time you hit the internet with it this way, too.
Works and Excel differed in several editions. You might not be able to just rightclick on the tab and ask select New Worksheet or Edit/Insert/Worksheet.
SOURCE: KODAK ALL IN ONE 5500 PRINTER KEEPS SAYING PAPER TRAY IS EMPTY
Shut down everything, printer and computer and try again.
