Question about Canon Office Equipment & Supplies
Canon MX860 Rear Paper Jam
Canon MX860 error message reads: ''Rear cover - The paper is jammed. Clear the paper and press OK.'' Opened rear cover and there is no paper. Cover is properly closed. Pressing ''OK'' just redisplays same message. Any ideas to fix this? Can't do anything with printer. Printer is less than a month old!
    New Friend:
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Posted on Sep 14, 2011
SOURCE:
MX860 error message reads: ''Rear cover - The paper is jammed. Clear the paper and press OK.'' Opened rear cover and there is no paper. Cover is properly closed. Pressing ''OK'' just redisplays same...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Office Equipment & Supplies
Paper Jam MX860
Double check as sometimes a small amount of paper will give this error message. If you are sure no paper is in the path/feeder, then unplug your printer from the ac supply for about 10mins (Logic reset) then plug back in and this should have this working again.
Sep 12, 2009 | Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
2,852 people viewed this question
Clive
Clive
old marine
old marine
Ekse
