Question about Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
Need adapter for the cable of msr206
Hi, i have a msr206 and its cable(from picture) ethernet to pc, but i want to connect it to my laptop and it doesn't fit.Where can i buy an adapter and how is it called? I need help quickly.Thanks
    Problem Solver:
  • 6 Answers
Hi dear
how are you ma bro ?
are you find any dump seller or dump+pin ...?
and what about your MSR is good working ?
i have new any Fresh dump now ?
if you want so please contact me ,
john.bro@hotmail.com
shah.sameer_1@hotmail.com /yahoo.com
i will slove your MSR problem t
thank you
john
Posted on Jul 05, 2009
How do I connect NEC versa Lx laptop to my dsl internet?
26200362-0w21o0w50atiexqhyc4a2yh0-1-0.jpg You need one of these PCMCIA network adapters. The one shown in the picture above requires an adapter cable (supplied when new) that connects the card to the ethernet cable. other later types of card have the socket on the card.
May 20, 2016 | NEC Versa VX Notebook
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
Can I hook my wifi laptop to my desktop and get online?
Hi there, you may be able to connect them together using an ethernet cable. When you do this you may need to bridge the connections to make them work. Once you have the ethernet cable connected go into network and sharing centre, then into change adapter settings. Hold the ctrl button and click (once) both of the adapter icons, then right click and select "Bridge Connections" This should sort your problem. (I am assuming that you are running windows machines)
I hope this helps.
Jun 02, 2015 | Computers & Internet
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
Where is the ethernet cable connected to this laptop
This is an older laptop that comes with a modem (RJ-11 on the back), not an ethernet adapter onboard. You can try to get a PC card ethernet adapter (type 2 or type 3 fit the slot) or a USB ethernet adapter. The USB port was not available on models that came with WinNT.
I wish I could be of more help.
Oct 15, 2010 | Panasonic Toughbook CF-27 Notebook
I need internet on yy pc card
You need an ADSL Modem & a Broadband connection. You run a cable from the Ethernet connection to the Modem/Router, and that connects to the telephone line, and then onto the internet.
Mar 03, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I can not connect the internet,because my laptop havs a problem with ethernet controller( yellow quwstion)
u can buy a cat5 cable.. or ethernet cable on the nearest computer shop.. and try to look for your nic. or network adapter.. if it doesn't have a problem..
Feb 11, 2010 | Computers & Internet
Is there an ethernet cable that will fit into a panasonic cf28 toughbook laptop as i need this in order to get it to go wireless
If there's an ethernet socket on the computer then there's a cable to fit it.
Most computers today have ethernet as standard (the socket and cable have been standard for years).
Why do you have to use the ethernet to connect wirelessly? Normally just activating the wifi in the computer and logging into the router is all that is needed.
Jan 06, 2010 | Panasonic CF-28 (cfwwl281m) Wireless...
How do you connect to the internet with the compaqnx9005? Do I have to buy a network card? Paul
Any "modern" notebook computer will have both an Ethernet adapter and a wireless adapter built-in, especially one labelled as a "business" model.
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Click the '+' in front of Network Adapters
to show the installed adapters.
Take an Ethernet cable, and connect one end to the Ethernet slot in your computer, and the other end to a cable-modem or a DSL-modem, and you'll have an Internet connection, through the Internet Service Provider of your choice (Comcast, Roadrunner, Verizon, et cetera).
Or, connect "wirelessly" at the local Starbucks.
Nov 27, 2009 | HP Compaq Business Notebook NX9005...
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
Unitech MSR 206-33 (msr206-33) Magnetic Card Reader Logo
383 people viewed this question
Top Unitech Televison & Video Experts
Michael Galve
Michael Galve
Are you an Unitech Televison and Video Expert? Answer questions, earn points and help others
