Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer drum has come loose, how do I tighten it?
Frigidaire stackable gallery Dryer drum has come loose, how do I tighten it?
  • 38 Answers
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Posted on Oct 04, 2009
Hi this is Lee of KY. I have a stackable washer and dryer. Iam having cloths damage by the dryer, the tub is loose and i think the cloths are getting pinched between frame and tub. I would like to try and fix this myself, how can i get some literature on how to fix this problem. Iam also having, what looks like grease stains on my clothing as well. Any helpful info would be apreciated. thankx lee
Posted on Jun 27, 2010
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
Our dryer is making terrible squeaking and bonking noises. The bonking came first. We want to look inside and see if we can fix it. How do you open the front or do you access from the back? Its the...
It sounds like the drive belt has SLIPPED out of the indented area (trough) of the indentation or it is loose, beginning to crack etc. OR one of the guide rollers has broken or gotten loose. Open it from the FRONT, taking off the metal cover. You will see the drum and the belt. Turn the drum by hand and inspect the belt, make sure it is in the metal trough, tight has no frayed, cracks in it. Check the guide rollers and the springs too.
Feb 06, 2018 | Frigidaire GLEH1642DS Front Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sheets literally get burn marks
Look for a loose Tub Fin and tighten it if its loose.Also,If the dryer has bad drum supports than it will allow this problem to occur.Other than that visually inspect the inside area in dryer to see if there is some thing sticking up that is catching the item.
May 21, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
1,849 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
