Question about Welch Allyn Tycos Harvey Dlx Triple Head Stethoscope Model 5079 DLXT
I have an older triple head Tycos Stethoscope that has a metal spring-like bridge at the bas of the ear tubes, and which holds the ear tubes separate. This broke near the connection with one of the ear tubes. Can this be repaired?, replaced?
    Problem Solver:
  • 6 Answers
If it's less than ten years old, it may be under warrantee. When mine broke, 15 years ago, I had to replace the whole Binaural/Spring Assembly piece- the metal ear tubes and the spring are all one piece.
Major med equip suppliers- Schein, Darby, etc., stock the parts. WA has them, probably for sl more-plus $10 extra charge for orders under $100.
I found them here:
http://www.steeles.com/catalog/Harvey_parts.html
http://www.welchallyn.com/support/service/default.htm
Posted on Nov 04, 2009
  • monique mares
    monique mares Jun 19, 2014
    Thank you, Thank you for posting the links. My doctor has had his set since he completed med school. Was insistant on not changing. So I m so glad to have the listed links. Sincerely, THE MA
Could you tell me what the torque specs would be to tighten the cylinder head on a KTM 85?
Thanks for contacting FixYa. I was reviewing some of the older un-answered questions trying to ensure your issue has been resolved.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
TF
Sep 03, 2011 | KTM Pag Spyder 300 Motorcycles
KTM EXC Head Torque Specifications
KTM Torque settings
TF
Aug 26, 2011 | 2000 KTM EXC 300
Whats the torque specs on the cylinder and head of a 03 ktm 125 sx
KTM Torque settings
TF
Aug 19, 2011 | 2008 KTM 125 SX
How do i change fork seals on a roadster 1983?
First you must get your bike off the ground in a safe manner so that you can work on it without it falling over. Safety first. Then remove the front wheel and the front fender. Take the brake calipers off. Loosen and remove the top nut on one tube. Work on one tube at the time. Loosen the pinch bolt on the lower triple tree. Slide the entire fork tube out of the triple trees. Hold the spring in the tube and turn it upside down and drain the oil from the tube. Take the spring out. Notice one end is tapered, this end goes into the tube first. Turn the entire tube upside down and you'll see a socket head allen bolt in the bottom of the slider where the axle goes. This is a "piloted hex key" bolt. It takes a special piloted hex key to remove it but you can get it out if you use a brand new hex key or one that has been ground off on the end so that the edges of the hex key are not rounded. The size is 6mm on most front ends. Take this bolt out and the top tube pulls out of the lower slider. The seal is in the top of the slider. Take the boot off, the snap ring out and pry the old seal out. Replace the seal and reassemble the tube in reverse of how you disassembled it. Get the tube back in the triple trees and add the correct amount of oil to the tube Use the quantity listed for a "dry" tube because you completely emptied the fork tube. Put the spring back in and replace the top cap. Then, go to the next tube. Do not forget to tighten the pinch bolt on the lower triple tree.
Good Luck
Steve
Jun 07, 2011 | Harley Davidson XLS 1000 Motorcycles
Torque settigs on cylinder and head for a 2002 ktm 65
Thank you for contacting FixYa with your inquiry. I have been going
over some of the older help requests that have been archieved and
trying to provide solutions for those that didn't get answered. Hope
this information helps.
KTM Torque settings
  13. Shock absorber bottom Shock absorber bottom bolt 60Nm 44ft lbs
  23. Other collar nuts on chassis M6 15Nm 11ft lbs
May 15, 2011 | KTM 300 EXC Motorcycles
I had to loosen the front shock to remove the front fender. ( New paint job). I unscrewed the top cap and released the spring. Now the threads are down in the tube to far to reach. How do I get them back...
Just pull up on the tube until it is as high as the other tube (even with the top of the upper triple clamp) and tighten the lower triple clamp so it does not slide down in the upper and lower triple clamp. If you do not pull the tube back up and tighten the clamps, when you push down on the spring to put the cap back on the metal fork tube will just slide down the clamps again.
Jan 22, 2011 | Honda VTX 1300 Retro Motorcycles
What is the torque for the head bols for a 2002 ktm 250 exc
KTM Torque settings
TF
Nov 07, 2010 | KTM EXC 300 Motorcycles
2009 ktm 125sx torque settings for head and cylinder
KTM Torque settings
TF
Nov 05, 2010 | 2008 KTM 125 SX
Head torque specs.on 1991 KTM540 2-stroke
KTM Torque settings
TF
Sep 03, 2010 | KTM MXC 520 Racing Motorcycles
Head tourque wrench setting
KTM Torque settings
TF
Apr 19, 2010 | 2005 KTM EXC 200
Welch Allyn Tycos Harvey Dlx Triple Head Stethoscope Model 5079 DLXT Logo
393 people viewed this question
Top Welch Allyn Health & Beauty Experts
Tom Chichester
denochearingaid
denochearingaid
adrohearingaid
adrohearingaid
Are you a Welch Allyn Health and Beauty Expert? Answer questions, earn points and help others
