Question about Refrigerators
On the frost free refrigerator water is coming from freezer down into the refrigerator going all over the top shelf
  • jazzspencer9 Jun 27, 2009
    Our refrigerator is not hooked up for auto matic ice marker, we don't know where the water is coming from but at the back of the freezer water is frozen long there then melts down to the frige and goes all over the top shelve.
  • 3,600 Answers
If it has an ice maker the hose is broke.
Posted on Jun 27, 2009
  • Bruce Hathcock Jun 27, 2009
    is it a frost free? if it is then there is a problem with the auto defrost or maybe a gasket allowing warm air to come in do you see any place it might be letting air come in? also is it thawing it out? be careful if it's thawing and freezing again you could get sick from it.
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Tip
Water leak from freezer? Ice on freezer floor?
Water leaks can come from may sources, this tip is designed to help with water that is from the freezer due to a defrost drain not working properly.
The Basics:
Frost free refrigerators have automatic defrost cycles. Without this automatic cycle the cooling coils would become covered in frost and the cold air could not circulate where needed. To rid the coils of frost every 8 to 10 hours a heater is activated for around 15 minutes, this is long enough to eliminate the frost but not long enough to warm the freezer temperature. During this defrost cycle the water that is created by the frost thawing is designed to flow down a drain into a pan under the refrigerator and evaporate from the heat produced by the compressor and condenser.
The Problem:
The drain that the defrost water flows down can get restricted and plug up or drain so slow it freezes. Depending on the model of refrigerator it can be a very easy fix or a bit more complex.
The Solution:
Locate the evaporator (cooling coils) they are going to be in the freezer section behind the shelves and back wall. On some side by side models you can simply remove the lower bin (drawer or shelf) from the freezer and you can see the drain opening. On most models both side by side, top mounted and bottom mounted freezers you will need to remove the panel from inside the freezer, this will require unplugging the refrigerator, removing the food and shelves and the panel behind the shelves, on some models you will need to remove an ice maker to get this panel off.
Once the panel is off you should see a tray, pan or trough that the water drips into off of the coils. In this pan will be a hole about the size of dime. This is the drain. If heavy ice is built up, you may not see it.
Be careful working around the evaporator coils, they can be sharp and also are very fragile, do not poke, chisel or pound on them. To remove the ice use hot water or a hair dryer. If a hair dryer is used be careful not to get the plastic walls of the freezer too hot. Use towels to capture the water as the ice melts, you do not want the water running on the floor.
Once the ice is gone and the drain opening is visible, take a turkey baster or syringe and squirt very hot water down the drain until the water runs down it freely. It make take a while, depending on how far down the blockage is. Have towels around the sides and front of the refrigerator to absorb any water that spills out of the pan when working on this and for a few hours after. Once the drain is clear, reassemble and enjoy a leak free refrigerator.
on May 03, 2010 | Refrigerators
I have a Kenmore Model 60192000, freezer on top and no ice maker. Have a leak on left side over top shelf. It is coming from apart in the refrigerator above the shelf, has kind of a square neck. I do I...
Is it a leak or a drip? A leak means you have continuous running water and a drip is more inconsistant.
I would suspect that you have a drip, that is caused by your cooling tube having frost or ice buildup in it, which is quite common for some units. The fix that seems to work the best is to defrost your unit, making sure the cooling tube is completely free of ice and frost by blowing hot air from a hair dryer down it. Then cutting a piece of bare electrical (solid core) wire that will fit down the tube but not extend past the opening. Then you form a hook and put it around your defrost heater.
That way the heat from the defrost heater will be transferred down the wire and keep the tube free of ice and frost.
Jul 28, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Our refrigerator is cooling and our freezer is freezing, but there is a leak coming from the freezer area that is dripping down into the refrigerator that just keeps getting worse and worse. Appears that...
Hi maabjcraft,
Have you tried clearing the drain tube?
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
May 18, 2011 | GE GTS22WCP Top Freezer Refrigerator
My whirlpool refrigerator is 4 year old. the ice maker is not installed I am getting water in my refrigerator now for over 5 months. There is no sign of water dripping down from the freezer or the back...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 21, 2011 | Refrigerators
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Water in my Fridge
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 15, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Water leaks from the freezer onto the top shelf of the refrigerator
Sep 04, 2009 | Frigidaire FRT17G4B Top Freezer...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
