The fan in the unit outside won't turn on,by pushing the contactor with a screwdriver it works but stops as soon I release the switch. Unit inside the house runs ok. Any help, thanks, Roberto
  • delafuentero Jun 30, 2009
    I'll try changing the capacitor ,which I suspected too. Now after removing the capacitor and the contactor , I drew a scheme of the wiring before doing so, there's an orange wire that I never saw connected to anything, that was hidden behind the contactor and I don't know where it goes. Frankly I think it wasn't connected to anything but I'm not sure, could it be? Thanks
  • 614 Answers
Most of the time it is fan capacitor. Sometimes bearing. But most of the time cap. goes bad. Get the info on the cap. If it is a dual cap it will say something like 25-5 35-5. Read these numbers. Buy a cap and hook wire for wire back. If not call a seervice tech and ask for free estimate on cost. That waat you will know upfront. Rus
Posted on Jun 27, 2009
Outside fan not turning inside fan running
Very impressive!! This button you are referring to is a contactor. When your tstat calls for cooling it sends 24 volts out to the contactor therefore pulling the contactor in completing the circuit for the fan and compressor. Usually this doesn't work when a safety switch is preventing the 24 from getting to the contactor. Either it's not getting a signal from the tstat or one of your safeties are tripping (high or low pressure) or the float switch on your drain line at the air handler is wired in to only stop the condenser from working rather than the tstat. A multimeter would be extremely helpful for you to determine where the voltage is stopping. Check your drain first, I don't suggest your patented rock idea, it's not running because of a safety. Good Luck , let me know!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 30, 2017 | Ruud UBHC Air Conditioner
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
The central air turns on, but does not cool. The fan outside of the house is not moving. Is there a switch I need to use to turn the outside fan on?
There should be an electrical box next to your exterior unit. Open it up and there should be a pull handle on an electrical bridge. Usually when it is turned one way it will make an electrical connection and if it is rotated 180 degrees and plugged in it won't make an electrical connection.
Jun 04, 2011 | Heating & Cooling
A/c outside unit is not working- fan will not work.
I assuming that the black box is a 100 amp breaker, which is connected to your condsensing unit (outside unit). If you open the box and pull the fuse then this will turn off/kill the power to your unit. As far as the buzzing noise it could be that the contactor is engaged. Hopefully, your fan motor is burnt out or the capicator is bad. If you take the access cover off and check for voltage at the contactor you should know if it is the fan motor. The voltage will come in at the bottom T1 T2 T3, once the contactor is engaged L1 L2 L3 will have the same power. Of course if your contactor is not engaging then thats the probelm, you can manual engage the contactor by pushing it in. There will be four wires two running to the capicator and the other to the contactor, these are the wires that control the fan motor. The other three wires run to your compressor. Hope this Helps Tim
Aug 03, 2010 | Heating & Cooling
I have t874r1434 thermostat. when I turn it on the heat pump model UPLA-030JAZdoes not quick. but the inside unit does. Sometimes it will work. WHY this problem,
Sometimes the contactor get welded shut. shut off the power to the outside and inside units. Go outside and remove the electrical cover. There will be a big black switch looking thing inside. (The electrical supply lines will connect to it). Some off these switches are open and some are not. If the switch is open just make sure it is pulled out. You can do this by pushing in on the button. If the switch has a cover on it, remove the top, with a Phillips screwdriver. Then proceed as above. If the contactor is pulled in pull it out with a pair of pliers. The unit will likely start functioning properly for a little while but the switch will need replaced as quickly as you can.
Jul 27, 2010 | Ruud UBHC Air Conditioner
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
AC not blowing cold air
Remove the outside fuse from the unit that is not cooling... remove all the sheet metal from around the outside unit.. see if there is a lot of grass/weeds/ bird nests, or other material in the coils.. if there is... use a high pressure hose to clean the coils completely!!!!! (I had this done to mine...worked much better!!)..if this doesn't help,, I am afraid it might be time for some freon... and yes..its $$$$...
Aug 11, 2017 | Amana Heating & Cooling
Outside unit will not come on
Check breaker. Take panel off outside unit you will see a contactor there with contacts. Take a long screwdriver and push the center of the contactor. If the unit runs you have a control problem. Check inside float switch. Most of the time it is located underneath unit. The new ones are on the front bottom of unit with two wires from the Switch Lift the float switch and see if the unit comes on. Make sure Tstat calls for cool. If it comes on you have a stopped drain. Take a shop vac find the outside drain from the unit **** out the stoppage.
Jun 12, 2009 | Heating & Cooling
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
