Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Electrical smell We have a whirlpool side by side refrig and this morning we noticed an electrical smell coming from it.  I tried to locate the specific location with my nose but was unable to do so.  Any suggestions on what it might be? Thank you!
  • 290 Answers
Re: electrical smell
The most common cause of electrical smell on these units is from the compressor start relay. Get behind the fridge and remove the cardboard cover at the bottom. The relay plugs onto the compressor. See if the smell is stronger there. Also listen for it to try and start the compressor. If it just humms and clicks off, the relay is probably shorted out and needs replacing. Do not let anyone put a "fit all" relay on it, some of them will work ok for a while but cause a compressor failure a few months down the road.
If the relay is ok, check the icemaker area. A burned icemaker module will sometimes give off a foul odor.
Post back if you have any questions.
Posted on Nov 06, 2007
0 characters
3 Points
Noticed smell in kitchen yesterday whcih made me think of an electrical issue or motor problem. Wasn't sure where smell was originating from This morning I am hearing a clicking sound from my Whirlpool...
the start device is cooked.pull out the machine and unplug it,remove the bottom panel in the rear and you'll see the compressor,on the side of it you'll see the start device,remove the clip and slide it off the the instructions with the new device and install it.if you open the fridge door,look up on the right side wall near the ceiling you'll see the full model number,you need that to get the correct part,you can send it to me or give it to your parts store.the same thing happened to me but i was lucky i had the part in my van,good luck
Jan 23, 2011 | Whirlpool ED5LHAXW Side by Side...
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frezzer won't freze bad smell just befor it quilt
Hi, thanks for visiting! The most common failure is going to be the compressor relay, located...well, on the compressor. It will likely be square and white in color. After unplugging the refrig, you can pull this little relay off and shake it. If it rattles, it is bad. Look for any discoloration or burnt wires as well. If bad, replace with new one from and you should be good to go!
Sep 16, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Burning smell behind refregratot. After fan trggered there is burning smell like rubber burning.
First , clean the coils under the front of the refrig , with a vac . Then pull the refrig out and remove the back panel and check that the fan there in working . If not , remove any obstruction or replace the motor ( pt # 4387244 ) . If the fan IS working , then replace the overload/relay , which is plugged onto the side of the compressor ( pt # 8201786 (comes with instructions )) . Both are easily replaceable and will save you hundreds in repair costs . Note : Dirty condensor coils ( bottom front ) can cause the overload/relay to go out .
Aug 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi, I have a GSS201EMD and have had the service tech here 3 times as the refrigerator part of the side by side is not cold. He has replaced the mother board 3 times to no avail. I checked this morning and...
I am having same problem. Freezer works fine but refrig will only go to 40 degrees verified multiple ways with 3 different thermometers that have been checked for accuracy. GE has been out twice and replaced control board and temp sensor but same problem, Did not notice where refrig temp sensor was located. Can anyboby tell me where it is?
Jul 23, 2010 | GE GSS20IEM Side by Side Refrigerator
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
It was working fine yesterday. When I got home I
Try unplugging refrig for a few min , then plugging back in . This will reset the adaptive timer and at least get the refrig working . The adaptive timer , is located in the control panel . Pt # 4388932 . To replace this board , remove the knobs and pro the top of the panel outwards . Remove the 4 screws holding the panel ( 2 are on the inside by the light bulb ) . You should now have access to the board .
Sep 30, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No Lights
sounds like you have abad electronic control board, its located behind the refrig, mounted to the left side(next to compressor) the machine will function ( with exception of lighting) heres the part number w10135090 retails for about $100, easy enough for you to change your self
Jan 10, 2009 | Whirlpool Refrigerators
Water valve
order the water inlet valve model specific. its located behind refrig where he wateline is hooked into
Mar 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
392 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
