Question about Bose Audio Players & Recorders
How keep the earplugs rubber inserts from falling off
    Problem Solver:
  • 5 Answers
Supa Glue does the trick
Posted on Sep 02, 2009
The black rubber top for the rubber joystick on my wheelchair keeps falling off where can I purchase a new one? It looks like a black rubber nipple
superglue holds rubber to metal very well , just don't use to much to run down inside switch but stays on tip
they now mfg a gel superglue for this very application (no run/no mess)
Jun 01, 2015 | Health & Beauty
How do eye masks work?
When your brain senses pure darkness, it causes the production of melatonin, the chemical of sleep. To help induce this state, you can also use earplugs. When you block out both noise and light, your chances of falling asleep are improved. People who sleep regularly during the day, such as nurses or other shift workers can benefit greatly by using them.
-http://www.dreamessentials.com
Apr 25, 2013 | Health & Beauty
If it is night time at my destination, should I sleep on the plane?
If it night time at your destination I recommend you to try and get some sleep on the way, on the plane, in order to avoid any symptoms of Jet lag. Earplugs, headphones and eye-masks can help you block out noise and light making it easier to fall asleep.
Feb 06, 2013 | Luggage & Travel
DOES THE APPLE ALLOW YOU TO PLAY MUSIC WITHOUT THE EARPLUGS?
The iPod does not have built-in speakers. You can plug external speakers into the earplug jack.
Jul 27, 2012 | Apple iPod MA446LL/A MP3 Player
Pro 95 scanner comes on, scand but no sound from speaker???
Insert an earplug connector into and out of the earplug connector several times. The audio will come back.
Feb 15, 2010 | Radio Shack Pro-95 Handheld Scanner
Right earplug is shorted out. sound goes in and out. how do i fix it?
The right ear plug internal wire is cut off due to wear and tear. This is common problem with earplug especially if
if you pull by the wire of your earplugs. The solution is to
cut open the wirings of your right earplug and reconnect,
resolder it, and tape the bare wires, to restore the sound. However, it will be unsighty. So, the best thing
to do is to buy another.
Oct 13, 2009 | Etymotic Research Isolator ER-6i Consumer...
One earplug(skullcandy) not working
yeahh happen to me too, you shuold get them replaced. Im about to replace my second pair :S There good headphones but try to keep it our of your pocket, because the wire becomes loose.
Oct 11, 2009 | Skull Candy Icon Headset
Wheels keep falling off
Yes. Using a drill press if possible, drill a 1/8" hole across the axle, install a washer on the axle after the wheel and insert a cotter pin through the new hole.
Apr 28, 2009 | Heavy Machinery
Missing Rubber Stoppers on Kinderkraft Crib Dreamer No. 305
You can probable just put a nail or srew in for now!
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail service@kinderkraft.com
http://kinderkraft.com/main.htm
Jan 13, 2009 | Kinderkraft Vermont Crib
PTT earplug problem
Hi, normally plugging in the earplug should cutoff the handset's speaker. If it does not cutoff it may be that the internal cutoff switch inside the radio is defective or slightly mis-aligned. This is a mechanical switch and could be adjusted by any competent technician. This might void your warranty (if still covered). Hope this works for you. Regards
Oct 24, 2006 | Motorola Talkabout T5100 (14 Channels)...
154 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
