Question about Ruud UAMB Air Conditioner
Condenser is buzzing so there is power, but the
Ruud condenser is buzzing, so there is power, but the fan won't kick on
  • clbranco Jun 27, 2009
    thank you rockitman187. it turned out the circuit was a tripped, prob. from the lightning storm last nite. all is well now. thanks for having me check the power
    President:
  • 2,559 Answers
The buzzing sound is from the contactor and only means you have low voltage at the unit,Check and make sure you have 240 volts at the unit and post back.
Posted on Jun 27, 2009
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
Condenser Fan stops turning.
If you have a amp meter you could measure the amount of current the fan is drawing and compare that reading with the amperage value printed on the fan motor.
More information is needed:
Is the compressor running?
How old is the unit?
What brand and size?
Are you getting a 240v where the fan connect to the power terminals?
Aug 27, 2009 | Ruud Central System Air Conditioner
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
Fan won't run, and buzzing sound
Motor's shot. New motor and capacitor should fix your problem
Jun 07, 2008 | Ruud UAKA030 Air Conditioner
Ruud out side unit
It sounds like you may have lost line voltage to the unit. What you hear is most likely the buzzing of the compressor relay which is energized by 24v from the indoor unit. Look at your condenser coil, are the aluminum fins clogged with debris? If so this is likely the cause of the tripped breaker and will need to be cleaned. Before you go to the trouble have someone go to your breaker panel and flip all the 220v DPST breakers off and back on while you watch and listen to the condenser to insure that the fan and compressor will come on line as soon as this is confirmed turn the breaker off and clean you condenser coil, the correct way to clean the condenser coil is to remove the disconnect plug at the unit or turn of the line voltage at the breaker, remove the top panel that supports the fan , flip it over being carefull that it's weight is supported in a way that wont stress the wireing harness to the fan motor. Spray the inside surface of the condenser coil with a heavy foaming cleaning solvent and let it have time to saturate the grime compacted between the fins then spray from the inside out and from the top down until the water runs free and clean from the inside thru the coil. Replace the top panel and allow time to insure that any water that might have gotten into the fan motor housing has evaporated, Then start it up if that was the original cause of the thrown breaker (very often is) then your in good shape and just saved a service call, Gratz!
Jun 07, 2008 | Ruud UBHC Air Conditioner
Ruud ubha
Does the fan on the outdoor condensing unit come on when the compressor does? If so, Is the condenser coil clean so that the airflow from the fan can remove heat from the condenser coil so the compressor won't overheat and trip the internal overload compressor protection circuit? If yes then is the indoor evaporator fan working properly? If yes are your filters clear and evaporator coil clear so that adequate air is flowing over the coil to prevent the compressor low pressure protection circuit from tripping? If so is the refrigerant charge on the system correct- either overcharged or undercharged can trip the compressor protection circuit. By now you should have come across an explanation for your compressor short cycling. If I had to guess I would bet on inadequate airflow over the condenser coil do to a faulty condenser fan motor either not turning at all or turning for a few minutes and then stopping when it overheats. This is likely caused by an unsealed replacment motor being used outdoors and water/rust has accumulated over the winter season and/or the capacitor is bad (in this case the motor may be turning slowly backwards) or just plain old worn out. I hope this helps get you to cold air sometime soon GL!
Jun 06, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UAMB Air Conditioner Logo
350 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
