My ford 2001 v10 f250 does not crank start or click what wrong change starter and solenoids
Might be bad starter relay, or bad ignition switch. Check for voltage to starter when key in start position, or turn on headlamps and try to start. If lamps dim, bad battery connections, bad ground, bad replaced starer. If lamps do not dim, starter position on switch may be bad. You could try using jumper from battery to start post on solenoid to see if it cranks. If it does, you have either a bad ignition switch, start relay, or wiring problem.
