Question about Kenmore 42822 Front Load Washer
It will not unlock. I have unplugged it twice yet it will not unlock
  • douglas_wood Jun 27, 2009
    I did exactly as you suggested. Neither worked. I unplugged it again. When I plug it in, the door is still locked. When i try to restart the wash, I get the dl,f reading. I also hear what sounds like a stuck electrical relay cycling towards the rear of the machine. Any suggestions?
  • 5,911 Answers
Locate the DRIN/SPIN button on the front panel. Press on hold for 3 seconds. This button is used to lock/unlock the front panel as a safety feature preventing small children from manipulating the controls. The instructions are printed on the front panel. If this does not work, unplug the unit for at least 30 minutes to reset the Central Control Unit (CCU). If you still need assistance, please let me know. I hope this helps you.
Posted on Jun 27, 2009
  • Jeff Rockwell
    Jeff Rockwell Jun 27, 2009
    body {
    background: #FFFFFF;
    margin: 0px;
    padding: 4px;
    font-family: arial, verdana, sans-serif;
    font-size: 10pt;
    p {
    margin:0px;
    padding:0px;
    .spwrap
    background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
    "Fdl" is a door latch error. The washer will attempt to lock several times
    at the beginning of the cycle. If the latch fails to lock, the washer will shut
    down and display the "Fdl" error code.
    Commonly, this is an indication of a broken door latch. However, in some
    case, this can mean a failed CCU which controls the latch. You can start by
    doing a visual check of the latch followed by ensuring all the connectors are
    plugged in and snug on the latch and at the point where they plug in to the
    CCU. Try unplugging each connector at the CCU and at the door latch (one at a
    time) and reseat them. This sometimes helps clear momentary problems. You can
    access everything by removing the top panel of the washer. Remove the panel by
    loosening the three screws that hold the panel in place in the rear of the
    washer. With the screws removed, the panel will slide back,, then lift off.
    The door latch is located behind the front panel. Follow the wires from the
    latch to the CCU, which is located directly behind the drum. For additional
    troubleshooting information, there is a tech sheet inside the washer behind the
    lower panel under the door. If not affixed to the panel door, it will be
    located along one of the interior cabinet walls.
    If you determine the latch to be bad, the following link explains how to
    replace:
    http://www.fixya.com/support/r587965-doo...
    If you have questions, please let me know. I hope this helps you,
Lid won,t unlock
press cancel twice and unplug. If that doesn't work then the lock maybe faulty.
Jan 18, 2016 | Maytag Centennial MTW5800TW Top Load...
Unlock control stick for jazzy select power chair.
Gerald,
Well there are a couple ways, One is push the start button within 10 sec. push the horn button twice. This should do it, but if it is a different Joystick then try, push the button to start then hold the Joystick forward until it beeps, then hold the joystick knob back until it beeps and then it should be unlocked.
Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Dec 04, 2015 | Select Health & Beauty
All controller lights are flashing
If they are flashing one after the other you maybe locked out. turn on then push the horn button twice to unlock, or turn on the joystick and hold the lever forward until you hear a beep, then all the way back until you hear a beep then the joystick should be unlocked. Check freewheel lever in drive position. unplug charger.
Oct 16, 2013 | Select Jazzy Used Electric Wheelchair
I forgot to turn the water on and now the door won't unlock and when i press Pause/Cancel twice unplug it and replug it, the machine will not allow me to restart
Take off the lower front panel and reach up the right side to the door lock you will feel a tab. Pull to release door . Try it again.
Nov 22, 2010 | Kenmore HE2 Plus Front Load Washer
Had to change battery needto know how to unlock security
Try to unlock the door twice with the key, then try to unlock the passemger door twice to disarm the alarm. This article are interesnting: Diagrams AUDI A4 1996-2003
Hope helps (remember rated this).
Jul 14, 2010 | 1996 Audi A4
How to I reset my keyless 2005 toyota prius? I recently brought my car to a collision shop to change my driver's side door. They told me they unplug the battery cable. In doing this, now my keyless does...
KEYLESS REMOTE PROGRAMMING
1- Driver's door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to
"unlock" a number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates
transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programming.
Jan 18, 2018 | 2005 Toyota Prius
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
How to unlock the scanner
Remove both cartridges from the printer.
Move the red lock switch (at the back of the printer) from the down position to the up position, and then move it back to the down position.
Unplug the printer and turn it onto its left side.
Then return the printer to the upright position and reapply the power supply.
Attempt this fix twice and then try to print and scan once more.
Nov 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Kenmore 42822 Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
