Question about LG 37LC7D 37 in. LCD HDTV
Picture freezing and discoloration!
I am having the same issue as everyone below. When I begin watching TV the screen freezes but the sound continues. I turn the unit off then back on and it does the same thing after a few minutes. Now recently I turn the tv on and the colors are mixed up primarily the red and green and it still freezes even when watching a DVD. I don't know what I should do if its worth getting fixed or buying another unit. Any help would be appreciated. The tv is just over a yr old.
    Genius:
  • 1,139 Answers
This is due to a buffer issue, to be more precise, the signal that comprises the picture and the audio are streams of data that go into a buffer and then into the processor. When the signal is at the proper level and the stream is not corrupted the image on the screen is ok, but when the signal is not at the proper level and the data stream becomes corrupted the pre-processor throws parts of the data away, and feeds the rest into the buffer wich goes into the main processor. Herein lays your problem if the main processor rejects the data or the buffer runs out of data due to the preprocessor throwing away data also you will get the screen freezing and pixelation (the square blocked dsicoloration you are talking about).
Now that we know what the problem is how do you fix it. First of all I would suggest following the owners manual procedure on downloading the software patch/upgrade for this TV. Then after using the software patch/upgrade, see if this helps. If not then you have a hardware issue. I have seen this problem caused by dried out or damaged filter capacitors (thes capacitors filter the DC voltage and if they go bad ther could be a relationship between the "dirty voltage" and the corruption of your data.
I any event I would suggest that you have a qualified TV technician repir this TV for to avoid any damage that may result from a missed procedure or lack of TV repair knowledge.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 27, 2009
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
My Toshiba TV freezes when I try to change channels, how can I fix it?
Try to do a system reset and check if it fix the issue and check below video:
else if the TV is under it's warranty period you can always ask the seller / dealer to fix or replace if it can't be fixed.
Oct 02, 2017 | Televison & Video
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
The picture on the tv is shaking and pausing/freezing for seconds at a time.. and discolored but no signs of permanant discolor like a cloud on the tv screen.. what could cause this?
This seems like an internal problem, and can only be solved by an experienced television troubleshooter, I suggest taking it to a professional.
Mar 11, 2011 | Sanyo DP32648 32 in. LCD TV
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Aug 04, 2009 | Televison & Video
Ilo dvdr04 freezing picture
have you tried using a laser disc cleaner after alot of use the laser eye can become dusty and make it hard to read
Aug 24, 2007 | iLO DVDR04
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
LG 37LC7D 37 in. LCD HDTV Logo
236 people viewed this question
