Question about NorStar M7208 Corded Phone
Compatability Issue? I have a single commercial line that does not work through the Norstar Compact ICS system. I have three other lines that work fine, but are from another source. The line will work from a buttset, but not through the system. Any suggestions?
  • lnarngr Nov 06, 2007
    Any assistance would be greatly appreciated as the provider of the line believes it is adequate. I know the equipment works, but is this line compatible with the cards?
What port is the line in? You will have to look in system programming under maintenance. Look and see if the port is enabled or not?
Posted on Dec 30, 2007
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Oct 01, 2010 | NorStar M2008 PBX Phone (nt9k08ad03)
We have a Compact ICS 4.0 with five lines. The first two lines are lit up as if someone is using them but we've reset all the phones and they're still lit up. Is there a solution to this?
They're tied up in the system the best way to clear them is to unplug the power cord to the CICS and re- plug it in. The system will take about 10 seconds or so to fully boot up.
Sep 29, 2010 | NorStar Lands Phones
CICS trunk issues
When the incoming call goes off hook (the indicator lamp will be solid, not flashing), press the associated line button to see which extension, or device, answered the call. You can follow through from there.
Good Luck!
Feb 15, 2010 | NorStar Compact Ics WithClid Trunk Mod...
How do I display my main number on all lines for caller id?
It's not in the maual, because it's not part of your phone system unless you have PRI trunks. On standard loop start central office lines, it's a function of the dial tone provider. Carl
Jun 10, 2009 | NorStar M7310 Corded Phone
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Jun 07, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Attendant still completes call after caller hangs up
Check and make sure that the disconnect clear time of ur Norstar is 800ms.
Apr 02, 2009 | Ics Norstar MICS (0x32) Modular Cartridges...
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
Norstar compact plus- can't get line access
make sure your wiring the co lines on the first 2 pins of the 66 then space 2 then lines 3 and 4.
Dec 09, 2007 | NorStar Nortel Venture EFA Phone
NorStar M7208 Corded Phone Logo
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
