Question about Frigidaire FGF334BG Kitchen Range
Frigidaire model fgf334bgwj the oven will not
Frigidaire model fgf334bgwj the gas oven will not light. the ignitor seems to be working.
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Hello, I have a Frigidaire
Oven ignitors get weak with age. They may glow, but need to reach a certain amperage draw threshold in order for the gas safety valve to open. Replace the oven ignitor part number 316001810. (note: low voltage can also affect the amperage draw, and thus the ignition, but is not very common a problem.)
Posted on Nov 29, 2008
  • 11 Answers
SOURCE: gas oven will not work.
the gas jet is proably clogged. Try cleaning with oven cleaner, if no luck use a pin on the the gas jet.
Posted on Aug 19, 2009
iwillfixforu
  • 619 Answers
SOURCE: Frigidaire Model FGF366CCB. (~5 yrs.
Using amp clamp with the igniter on should 3.2 amps or higher. Change the igniter, even tho it is glowing it is not pulling enough amps. Common problem and will fool you.
Posted on Feb 02, 2010
SOURCE: model fgf334bgwj gas range oven
When the ignitor glows brightly and the oven doesn't light it is usually a defective ignitor. The way to know if the ignitor is good or bad is to read the amp draw of the ignitor with an amp or watt meter. The gas valve and the ignitor are wired in series and for the gas valve to draw the current the ignitor has to draw 3.5-3.8 amps.If the ignitor is drawing 3.5-3.8 amps the new gas valve is defective. If it is drawing less amps the ignitor is defective.
Posted on Jul 25, 2010
I have a Frigidaire model FGFL87DCE gas range and the oven will not work. It doesn't light and the gas doesn't come on
the first thing to check is the ignitor.turn the oven on and look to see if the ignitor is getting hot if it not you will need to check the power to the ignitor.if there is power to it then you may neeed to replace the ignitor.
If the ignitir is not drawing enough current then it will not open the gas safety valve
Dec 11, 2010 | Frigidaire Ovens
My frigidaire self cleaning stove(FGF368GM ) isnt lighting.... how do i light my stove?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire oven will not ignite
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 23, 2010 | Frigidaire Ovens
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Oven won't ignite, top burners work
Faulty Ignitor, Check the ohms,if you don't know how to do this....change out the ignitor...this will fix it...
Oct 01, 2009 | Frigidaire FGF334BG Kitchen Range
Gas oven will not work.
Aug 19, 2009 | Frigidaire FGF316 Gas Kitchen Range
Model fgf334bgwj gas range oven will not operate. I removed the oven bottom plate and deflection plate , the glow bar turns on but no gas flows to ignitor? Is it the gas safety valve?
Jan 25, 2009 | Kitchen Ranges
Oven won't light
Tip - do not change the safety valve first even if the ignitor seem "ok" if you gently tap the safety valve and the flame comes on initially but fails to come on after awhile after each"tapping" - the ignitor is the most likely culprit
Jun 12, 2008 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire FGF334BG Kitchen Range Logo
175 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
