Question about Samsung Weather Resistant Security Camera SSC-12C
Wireing ALL I HAVE IS THE CAMERA AND I NEED TO NO WHAT WIRES ARE WHAT FROM RIGHT TO LEFT
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Posted on Nov 25, 2009
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
Dec 07, 2012 | Samsung Soc-a101 Hi-res Outdoor Bullet...
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
I have a 2000 chevy impala i cut wires on factory n dont know what wires go to what on after market stereo need to know what colors on factory harnus r what ex-orange,illuminate orange 2...
2000 Chevrolet Impala Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 03, 2018 | Chevrolet Impala Cars & Trucks
Need to find out what color wires to use to fix my enforcer infared security camera the wires got cut. Color wire for splicing the wire on.
I have a small color security camera with infrared that is intact. This camera is an exclusive Harbor Freight Tools distributed product. I have attached pics of it, the last pic of the small connecting box looking into the connection starting from left to right are 4 wires 1=yellow 2=blue 3=orange 4=white. I hope this is of some help to you. I unfortunately don't have the other end of the connector and am looking for pinouts to hard wire it to my monitor. If some one has this info please pass it on to my email zimpmd at aol. Thank You Michael Zimpleman
Jun 05, 2011 | Cameras
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifier┬┤s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
I need to locate the position of the Radio/CD booster amplifier
hi...
please check weather these wires are secured properly...
these are the wires coming from the player please trace whr these wires go you can get the booster amplifier
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
if my answer was usefull please vote
Jul 14, 2010 | 2005 Chrysler Town & Country
I need to know which color wires are specifically for which speakers
The 2 white wires are for the front left, they gray wires are for the front right, the 2 purple/violet wires are for right rear speaker and the 2 green wires are for the left rear speaker.
May 19, 2010 | JVC KD-G120 CD Player
Just got a clarion xmd1 but the wires are cut off at the plug
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Jul 30, 2009 | Clarion XMD1-RET CD Player
Need information
This plug configuration should be the same as the old autotek. The wires on the sides of the remote are the positive speaker wires. With the amp orientated so that the 3 wires are on top, the wire left of the remote on the amp plug should be the left positive. The one directly under it is the negative for that channel. The ones to the right are the right channel (negative on bottom again).
You can confirm left/right after you get the amp powered up. Drive signal into one RCA jack at a time and check for output on the corresponding speaker wires.
Apr 12, 2008 | Car Audio & Video
WIRES!!!!
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Oct 29, 2007 | Clarion DB255 CD Player
Samsung Weather Resistant Security Camera SSC-12C Logo
1,983 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
