Question about Poulan Pe550 Gas Edger
Engine Stalls out
When I first start engine it runs fine for about 5 minutes then begins to lose power and stalls out. Have to wait 10 or 15 minutes then it will restart and do same thing. any idea what problem may be
  • 1,041 Answers
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
2006 VW GOLF TURBO DIESEL 1.9 STARTS UP GOES 5 TO 9 MILES STALLS WAIT 5 MINUTES GO AGAIN AND STALLS
Hi. It would be useful to get a code read and some live data from a decent diagnostic tool. There are quite a few possible causes including, pressure in tank - if the fuel tank can't vent pressure then a vacuum will eventually form stopping fuel getting to the engine, this will cause it to loose power and stall. Then after a few mins the pressure will drop and the process start again, easy test is when the car stalls remove filler cap - if that's the fault there will be an audible hiss and the car will start up again.
part blocked exhaust will have same problems but will more generally cause a lack of power and acceleration.
are there other symptoms? i.e only when conering or only when pulling off or stopping, engine light on/off. Jon
Dec 18, 2014 | Cars & Trucks
Ford excursion 2002 - starting fine but losing power and stalling after running for 10 minutes. Rest for about 5 minutes, then starts up again
Can you perform a spark test? I would like to know if it has spark when it stalls. Also, if you have a can of starter fluid, wait for it to stall and not want to restart, the quickly spray some starter fluid into the intake. If it runs on the starter fluid, you have a fuel issue. You might also want to make sure the engine coolant level is fine and you aren't overheating. If you coolant level is low you may not know it is overheating since the coolant sensor isn't in coolant. It won't read air.
Jan 28, 2014 | Ford Excursion Cars & Trucks
2001 nissan altima loses power while driving.
Sounds like you may have a wire heating up and grounding out or a wire loosing contact.
Apr 13, 2013 | 2002 Nissan Altima
2002 Malibu stalls while driving, doesn't over heat. But can start smelling gas fumes before it stalls. usually wait about 5 mins then restarts. in higher elevation runs fine but in lower elevatio
It sounds like the catalytic converter could possibly be almost completely plugged up not allowing the exhaust to leave the engine like it should. It just builds up in the cylinder head and when it gets too much in it built up and there's no where to go, it'll stall the engine. By letting it sit for a few minutes, it gives the exhaust time to find a way out and the car will restart.
Mar 27, 2013 | Chevrolet Malibu Cars & Trucks
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 12, 2011 | Chevrolet TrailBlazer Cars & Trucks
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 07, 2011 | 2004 Pontiac Sunfire
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
Aug 06, 2011 | Oldsmobile Alero Cars & Trucks
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Jul 29, 2011 | 2005 Pontiac Grand Prix
Engine loses power and stalls
try adjusting the throttle position switch very hard to adjust right car will hesitate , not idle properly and hesitate when accellerating if not adjusted properly.
Jan 23, 2010 | 1991 Volvo 740
Poulan Pe550 Gas Edger Logo
432 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
