Question about Kenmore Washing Machines
Replaced the safety switch on a mdl 70,now it filled with water but that's all it will do
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!
Posted on Sep 15, 2010
Gas heater fills, lights and water pipe is hot. Only luke warm water dispenses. Have replaced thermostat/gas control and thermocouple. What now?
make sure that you do not have a water temp mixing control valve in the out let pipe from the system
that is a safety requirement that stops the hot water from going over 70 C to prevent hot water burns
Jan 28, 2018 | Water Water Heaters
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Water does not shut off when filling a load with new lid switch
Hello friend, The guy at sears is wrong. All replacement water pressure/level switches for your washer model 70 series MUST have the clear tube replaced on them or the washer will not work. Re-install the clear tube on the new part and your problem will be no more. Happy to help.
Oct 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
70 series washer will not fill with cold water, only with hot wat
hot/cold selector switch replacement imminent.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Series 70 washing machine Will not fill with water
Sounds like your pressure switch behind the control panel is stuck. Try unhooking the tube going to the switch and see if it breaks free. If not replace the switch.
Nov 19, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Dishwasher wont fill after repair
first check to make sure the water is on then take the kick panel off and make sure the float is engaging the safety switch and the valve is plugged up if all that's ok check to si if the mirco safety switch is good
Feb 11, 2008 | Dishwashers
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
