Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
CS30 starts, runs 10-30 sec., stops
Blows thick white exhaust. Using a good fuel mix, don't have any cracks/leaks, air filter clean, etc. All the usual suspects seem to be OK.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>If the Muffler and Exhaust Port are Clear, then
>>Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor.  Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf   .
You can View a Breakdown of this Unit at this Site Addy; http://www.ryobitools.com/parts and Select "Go to Ryobi Outdoor Parts Store". Now Select "Repair Parts Catalog". Select I Agree to Terms. Now Enter the Model Numbers and Click Search. Now Double Click on you Model in the Results Area.
>>If you Hit a Snag or this Does Not Correct the Problem,  I am Here if You Require More Assistance. Hope this Helps.
Posted on Jun 28, 2009
    Novelist:
  • 103 Answers
Thick white smoke from your exhaust is an indication of a blown cylinder head gasket. Your coolant is mixing with your oil and fuel producing this white smoke. Try replacing this gasket and doing an engine flush. You may need to purchase a new motor if that does not work.
Posted on Jul 05, 2009
I have a SRM2100 trimmer, it will not run unless the choke is full on and of course after it runs in this mode a little while, it fouls the plug and quits. I cleaned the carb, installed new kit, new...
hi there jaybolt
here is a website for parts
http://www.partstree.com/parts/?lc=echo&mn=SRM-2100+Type+1+S%2FN%3A+001001+-+159490
all being well and compression and spark and timming , muffler is clear , carby is clean , and diaphrams are all ok you mention carb rebuilt , fresh mix , and fuel filter and lines are good
does the unit run with 2 stroke mix in the plug hole - then stop ?
if yes assume compression and spark are ok,, if no check compression and spark and muffler
will the unit run with 2 stroke mix sprayed into the carby throat, then stop ?
if it does sounds like you have a air leak somewhere in the intake system
could be at barrel base gasket, c/case joint, manifold boot/ block gasket, carby gasket , impulse hose ,if this unit has one , c/case main seals leaking
2 strokes need air tight c/cases in order to pump fuel / air / oil mixture from c/case to cylinder
and to create a vacuum for entry of fuel/ air / oil mix from carb to c/case
symptoms of air leak are -: hard to start, wont idle, stalling, low power, inconsistant idle, over rev
overheat
pressure and vacuum testing can be done by blocking off intake and exhaust with rubber and metal plates , then fitting adapter to spark plug hole , and placing piston at bdc , pressureise cylinder to 7 to 8 psi of pressure and check areas , base gasket, manifold joint, main seals, , impulse hose ? for leaks with soapy water - if leaking bubbles will be evident
if no leaks and pressure is held at 7 psi for at least 2 minutes with dropping - presure test is good
next do the same test using vaccuum again go to 20 - 30 inch / vaccuum
if vaccuum held unit is ok
suggest take a good look at carby and recheck its rebuilt correctly and setup particularly if P and V test are good and spark coil tests good with a coil load test using a spark gap of 6.00 mm to stress the coil ( simulates spark under compression load)
have a look and let me know what you find
cheers pauly46
Jul 03, 2011 | Echo Garden
98 grand prix 3.8 non-supercharge starts but wont stay running have to keep foot on gas pedal to stay running blows out white some trough the exhaust. no coolant in oil what is causing this
If it is blowing thick white smoke that is coolant. You can lose a head gasket in places where only coolant passages go through so you don't always get oil/coolant mixing when this happens. Take the radiator cap off and see if air bubbles through it. You can also try pulling the spark plugs to see if one or more looks really clean.
Jun 04, 2011 | 1998 Pontiac Grand Prix
Tanaka TBC 160- very hard to start, any suggestions for possible reasons? Replaced the gas mix but it starts up & then stops running. tried new gas mix, checked throttle- seems to operate, Any...
hi there
paul 46 here.
all being well and compression and spark and timming , muffler is clear , carby is clean , and diaphrams are all ok , fresh mix , and fuel filter and lines are good
does the unit run with 2 stroke mix in the plug hole - ?
will the unit run with 2 stroke mix sprayed into the carby throat ?
overheat
suggest take a good look at carby particularly if P and V test are good and spark coil tests good with a coil load test using a spark gap of 6.00 mm to stress the coil ( simulates spark under compression load)
cheers pauly46
Apr 30, 2011 | Tanaka Commercial Grade "Inspire" Design...
When first started black smoke comes out exhaust pipe,, what could this be
Black smoke is burning oil. Blue smoke is usually transmission fluid due to a leaking modulator valve in the older auto transmission. White smoke is due to water getting in to a cylinder from a bad gasket, cracked block or a cracked head. Black smoke from engines on starting and/or running tends to mean there is fuel leaking into the engine, or the fuel mix is incorrect and not atomised correctly. the main causes are normally a nakered air filter that isnt letting enough clean air into the engine to mix. a blocked fuel filter, which is either not letting enough fuel in, or in some cases, a faulty fuel filter which is letting too much fuel into the engine, and causing black smoke due to excess burning. Black smoke is a fuel/air mixture suggestion problems with injection or carbonation. Cause of black smoke is due to running rich in the fuel air mix. Check the oil,the oil leak,the air filter,the fuel pump and fuel filter to confirm the fault.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 22, 2010 | 1986 Mercury Grand Marquis
I have a Craftsman High Wheel trimmer that will start fine then run for a few seconds then stop. It's seems like a fuel problem but not sure. I changed the air filter but thats all. Any ideas
Lots of things can go wrong with fuel delivery on these machines. carbon builds up[ in the engine and muffler system...ethanol laced fuel helps break down the sensitive carb parts and especially the fuel lines.
If you feel like it,open up the carb and take a look inside for any debris especially on the real fine mesh screen on the fuel pump side under the mylar diaghram. Check inside the fuel tank for a bad/dirty fuel filter and/or brittle fuel line...Fuel lines develop cracks and holes, thus leaking air and affecting the carbs operation. A rich mix starts these engines but if the mix becomes too lean, they won'd idle and if you run them too long this way you can cause engine damage due to the lack of gas./oil used with so much air entering the system. Don't be afraid to look around and poke around for other problems. Pull the spark plug and either clean it real good or replace it. It gets a build up on it sometimes that needs to be removed (especially down around the electrode insulator (the white part under the tip).
Jul 08, 2010 | Craftsman Garden
I changed the plugs & cap, rotor, wires ,coil & fuel filter. the motor is still running rough.
If there's black smoke coming out of the tail pipe check M.A.P sensor for good vacum and coolant temp. sensor, both will work like a choke, if that check's out it 's going to be a bad fuel line leaking to the injector's or a fuel regulator, both sit under the in take, getting to much fuel will make it run like it need's a tune up.
May 17, 2010 | 1998 Chevrolet Blazer
883 Sportster burning rich
hi,it sounds to me like the bike is actually running to lean,or,you have a leaking exhaust,what happens is when you let off the throttle,clean air is drawn into the exhaust through any leaks,the next time the bike fires,the hot exhaust gasses mix with the air in the exhaust and you get a backfire when they all ignite,check your exhaust system for leaks first,if you can feel air coming out of seams etc when the bike is running then air can get in to,changing theair/fuel ratio is quite easy,simply with a screw driver turn the screw in(richens mix)untill the bike starts to struggle,then back it out untill the bike settles into a nice steady idle,if you take itout to far(leans out the mix) the bike will again start to struggle,all you have to do is find the mid point between the two and you will have the mixture pretty close to bang on.if you are not confident to do this ,take the bike to a shop and have it done,it will be a relatively short visit and wont cost much...hope this helps..cheers
Apr 01, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Blower would not run at anything above 1/2 throttle. then it would not start at all. put a carb kit in and not it starts and runs at higher rpms but when it warms up it dies. when snapping the throttle it...
If the gas is old, for example, last season, change the fuel ..drain the tank, carb and fuel line.
Also clean the air filter... this can have similar effects on start/run.
Pull the spark plug and clean it also, you can use spray carb cleaner on the tip, and then clean with fine sandpaper.
then replace the fuel with fresh fuel/oil mix.
A good spray can of carb clean will work to clean any build up in the carb jets, fuel line etc...
Oct 30, 2009 | Ryobi Backpack Blower 25.4cc
Starts then stops , acts like it ran out of gas
Make sure that your fuel mix is correct and clean. Also make sure there are no air bubbles trapped in the fuel line. Agitate the fuel tank to make sure there is no blockage caused by dirt and debris, and if you have a fuel filter fitted, then make sure it is clean and does not need replacing.
Next check the air filter to make sure it is clean.
Next check that the spark plug is whitish grey and matt in colour and not back, oily or pure white. If so then change the plug and set the correct spark gap for the particular type of plug you are using. If the plug is black and sooty or pure white matt then the fuel mix is incorrect and you will need to adjust this. Black indicates too much oil in the 2 stroke and burning low and the white indicates over temperature and probably not enough oil in the fuel mix or using to high an octane rating. If it is oily then there is far too much oil in the fuel mix and if you are using a 4 stroke or a 2 stroke with additional lubrication then there is oil leaking into the combustion area most likely caused by a worn or cracked piston ring. After that check that the carb is operating correctly and opens fully when starting and closes as the engine warms upon idle. Also make sure that it idles evenly. Also if it stops when you throttle it then look at the spark cap to make sure it is not loose or damaged and produces enough voltage to fire up the plug correctly otherwise you may have a generator issue or a carb problem or air filter problem or something restring air flow. Also check the engine casing over for any cracks or damage.
Oct 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
99 kaw600 ninja runs great upto 6000rpm then falls on face.Cleaned fuel filter,looked for shorts,chaned gas,cleaned carburetor(140 main jets)no change.The bike has a D&D exhaust on it.HELP!
Hi and welcome to FixYa,
It would seem a lean air/fuel mix. Pls check your sparkplugs and note color. If it is very light brown almost whitish, then it is confirmed to be lean. If so, possibly an air leak in the airbox/enclosure. Another possibility is if the bike is using aftermarket free breathers such those from K & N. If yes, try restricting the incoming airflow. Temporarily install upholstery foam over the after market air cleaner. You may have to experiment with the thickness.
Would appreciate a postback on the results and any developments.
Good luck and thank you for using FixYa.
May 12, 2009 | 1999 kawasaki ZZR 600
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
774 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
