Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
A
Anonymous Posted on Jun 23, 2014
Manual for compaq presario SR1103WM-B - Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Bob Sloan
Level 3:
  • Compaq Master 2,013 Answers
  • Posted on Jul 30, 2014
Bob Sloan
Compaq Master
Level 3:
Answers
2013
Questions
Helped
356929
Points
8519
The Manuals are here... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=424182&
However, if this machine is running XP, or earlier, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one.
Good luck
5 Related Answers
Anonymous
  • 268 Answers
  • Posted on Feb 24, 2009
SOURCE: record music to cd
You need to get a program to burn your music to a disc. I recommend a program called "DeepBurner", it is free and very simple to use.
Anonymous
  • 319 Answers
  • Posted on Mar 03, 2009
SOURCE: The cd tray on my compaq presario desktop wont close
The drive should be replaced. they are fairly cheap (like under 50 bucks) and simple to install. sorry about your untimely issue
please rate
Anonymous
  • 92 Answers
  • Posted on Jun 13, 2009
SOURCE: manual for presario sr1103wm
Here is a link to all the manuals for your computer. Link
Please don't forget to rate this solution.
Anonymous
  • 5 Answers
  • Posted on Jun 20, 2009
SOURCE: My usb keeps sayin power surge on hub ports
You may need to upgrade to a higher wattage power supply, which would also help with the performance of your computer. Or try updating either your system bios or USB drivers.
Anonymous
  • 855 Answers
  • Posted on Oct 08, 2009
SOURCE: My Compaq Presario SR1103wm doesn't have cd-rom
If your not familiar with the insides of your cpu. You can purchase an external cd/dvd/rw drive and hook it up. usually with a usb or supplied cable. To install depending on type and brand just follow the instruction that come with it. They do work very well.
1helpful
Looking where i can find the restore disk for a HP Compaq Presario SR1103WM please help me
Telephone HP, and order a set of the "System Restore" CD-ROM disks.
Probably about $20, plus $20 for overnight-courier delivery.
Stumped on sound!
Ok heres what you do to fix the walmart compaq I have had many people having this issue. first off remove the driver from the system then have the computer research the system to find it then update driver this should fix your problem
1helpful
My Compaq Presario SR1103wm doesn't have cd-rom insalled. Or so the system tells me,I believe it because I can't get it to read one single disk.How do I install it?
Manual for presario sr1103wm
1helpful
Lost factory disks for my Compaq Persario sr1103wm know were I could get a new one?
Most HP and Compaq desktop PCs that ship with Windows Vista and XP do not come with recovery discs. Instead, they use a partition on the hard drive. To access a hard drive recovery, turn on the computer and repeatedly press F10 (XP) or F11 (Vista) until a Recovery window opens.
please rate
Record music to cd
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Needed Model# to help with Graphic Card
Your system model no. is :-PC182A-ABA SR1103WM NA430
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
