SOURCE: have compaq presario v2000 notbeook.
Does this also happen without the battery inserted. Unplug everthing possible including DVD drive and external devices.
According to this site: http://www.bioscentral.com/beepcodes/compaqbeep.htm one long neverending beep is also bad RAM. If you've replaced the ram then the only other explanation is the memory controller on the main board, looks like you'll have to replace that too. First check that the RAM is inserted properly. Try a single RAM module if possible. Does this unit have built in RAM? If so then the main board needs to be replaced. Also make certain that your new RAM is the proper type and speed.
Good Luck!
SOURCE: Added max memory to my Sony Vaio PC RX650. PC won't boot.
if you have P4 Desktop then u can up-grate you PC up to 2GB RAM
be for you buy chack your dimm frist what is modle of RAM
isit DDR 400 or higher
SOURCE: Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
