Question about Whirlpool LER5636P Electric Dryer
Model LER4634EQ1 runs but no heat. Does not shut off
Dryer runs continuously. Must "turn off manually" vs automatically shutting down at end of "cycle". But, does not heat.
Illeagle
  • 525 Answers
SOURCE: no heat after first cycle
This condition is normally caused by a faulty cycling thermostat. Movement of the timer in the auto-dry mode is controlled by the cycling thermostat. Movement of the the timer in the time-dry mode is not controlled by the cycling thermostat, but by the timer motor.
Below is a link directing you to an enlarged image of the thermostat. You will also find other pages within the website with exploded view diagrams and disassembly procedures, prices and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=601359&PPStack=1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
docjohn174
  • 943 Answers
SOURCE: whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
Posted on Oct 06, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
spc_jschuck
  • 13 Answers
SOURCE: Dryer won't shut off at end of cycle
First of all if you want heat it's probably a burnt up thermal fuse due to lack of air to the dryer. But if the timer is getting stuck you'll just have to replace the timer. Theres no way of fixing the timer just replace it and then replace the thermal fuse (it's located on the back of the dryer) and you should be up and running also have the ducting cleaned out.
Please remember to unplug the dryer before working on it.
Hope this helps
Jason
Posted on Apr 01, 2009
Electrolux model FEQ332CES0 spins but there is no heat. Any suggestions on why and how to repair the problem myself, thanks.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 08, 2015 | Electrolux Dryers
My kenmore dryer model#110.61202013 wont heat up
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Feb 22, 2015 | Kenmore Dryers
Maytag dryer stops after few minutes
Feb 21, 2015 | Maytag Dryers
Dryer is not heating up property
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 30, 2014 | Dryers
Kenmore model 110.69422801 Good voltage all components ohm out ok, spins but no heat. can the timer on this model cause this?
GOD IS STILL GOOD !!!!
Sep 23, 2014 | Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Will not heat model 592-891070
Aug 17, 2014 | Kenmore Dryers
What is wrong with my gas dryer ? no heat and wn't shut off.
FIRST OFF IN THE AUTO DRY MODE THE DRYER USES THE MOISTER SENSOR AND AS LONG AS THE MOISTER SENSOR DOES NOT DETECT HEAT OR DRIED CLOTHES IT WILL CONTINUE TO RUN FOREVER.
NEXT AS FOR UR NO HEAT:
Aug 09, 2014 | Kenmore Dryers
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
161 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
