Question about Hitachi 50UX57B 50" Rear Projection Television
Power failure The power just shut off by itself. It was turn on for an hour and suddenly it shut off.
  • 2,200 Answers
The television shut itself off after an hour is that right?
Is the television working again when you power it up?
Is so I have the solution.
Please post a comment to clarify the exact symptoms and I will troubleshoot the issue for you.
Posted on Jun 27, 2009
Why Intermitant Power Loss
Its probably a Power Supply failure replacing it will mostly fix your problem
Jun 20, 2014 | LG 42LD550 42 in. TV
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
Feb 06, 2018 | Televison & Video
Sudden shut down
It's possible that this is a hardware failure or a power adapter failure. Try to reset the unit and reinstall it again. You can also check for firmware updates available online. Try to use other power adapter as well with the same specs with the original power adapter.
Jan 25, 2014 | Linksys Computers & Internet
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
Computer just turnoff suddenly
Could be one of two most common problems?
#1
Have you ever replaced the CPU Cooler (Heatsink/fan)?
CPU Cooler fan may be working, Heatsink dirty.
CPU is over-heating = mainboard turns off
Replace CPU Cooler
#2
Power Supply fan not working causing partial failure on 5volt or 12volt side.
Replace Power Supply
There are more causes but these are most common for short-time boot problems.
Another could be hard-drive, but that wouldn't shut system down like first two would.
Apr 04, 2010 | Sony VAIO PCV-W500GN1 PC Desktop
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Why does my converter box turn itself on and shut itself off?
set your power down to off most boxes are set to turn off in 4 hours
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
TV suddenly stopped working; not will not power up at all.
it may have overheated
or it blew a internal fuse
if this is the case you may be covered under warranty. if warranty is expired contact
http://www.tacp.toshiba.com/customersupport/contact.asp
Apr 29, 2009 | Toshiba 26HL83 26 in. LCD HDTV
Hitachi 50UX57B 50" Rear Projection Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
