Question about Husqvarna Chain Saw 20" Bar
Husqvarna 359 EPA - no spark. I replaced the spark plug. is there a reset button? What do I check?
  • 3,600 Answers
Check the kill switch button wire see if it broke off that happened to mine an dcaused a no start and if the air filter is not clen it won't run eaither.
Posted on Jun 27, 2009
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Husqvarna 359 Won't fire. left it for 2 days, fired right up this time. Idled high so: snapped off the L/H jet stoppers (emission regulation). adjusted low jet, went for H jet, kept trying to die as I let...
You need to pressure test the carb, if the needle is leaking you will never get to run well, if you have fitted a new rubber tipped needle and it still leaks you will have to replace the carb, the later carb was a Zama rather than the Walbro, it made the saw run so much better.
Sep 16, 2013 | Husqvarna Garden
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
Oct 04, 2012 | Husqvarna Garden
My 359 etech will start running bad after cuting one or two sticks of wood then die. If it sets until the next day It will again start. It has a good blue spark even when it won't run. It won't even...
If it still has a good spark it must be a fuel issue, replace the filter in the fuel tank check the fuel hose up to the carb for cracks or splits, if this does not help the next step is to service the carb, let me know if you need help with this.
Apr 03, 2011 | Husqvarna Garden
My 359 saw will not start was running then i cut it off would not restart looks like fuel is comeing out of mufffler it is getting a spark
Try a new plug.the gap is .028-.030.Sometimes the plug gets wet and won,t spark hot enough too rerstart.
Nov 23, 2010 | Husqvarna Garden
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Brand new 359 chainsaw won't start
As this is a brand new chainsaw, DO NOT start taking it apart and tinkering with it, for the simple reason that it is covered by the Husqvarna warranty and you should be able to have it either repaired or replaced without cost to you!
Here's the web link for Husqvarna customer support. You can also contact the place you purchased it from, as they should be an authorized dealer in order to sell the Husqvarna chainsaw products.
http://www.husqvarna.com/us/homeowner/support/customer-support/
IF, you bought this from a friend, etc., it would still be covered if it's new and unused when you purchased it.
That is the best recommendation you can get for resolving your issue and to keep your warranty valid.
Since without more detailed information, (gas is flowing into carb, spark plug getting spark, good compression, plug not fouled, on/off switch not malfunctioning, kick back/chain bfreak working, etc., etc.), no one can possibly provide an answer to resolve the issue.
Hope you find this Very Helpful and best regards!
Aug 13, 2009 | Husqvarna Garden
Husqvarna chainsaw model 359 will not restart after refuel and bar+chain oil refill. Prior to the refuel it was starting within a few pulls. I was bucking a felled pine tree(36'' dia) and saw was running...
Make sure you use the highest octane unleaded fuel you can buy. Make sure your mixture is exactly as prescribed, even the slightest deviation can be a problem. My Husgavarna 359 had the problem just like yours when it was new, new. I would have to take the spark plug out and let it dry out or blow it out with air. It would then run like a top.
Apr 14, 2009 | Husqvarna Garden
Husqvarna Chain Saw 20" Bar Logo
289 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
