Question about Curtis RT700 7 in. Portable Television
Is this a digital tv or just analog? Thanks
  • hooah773 Jun 27, 2009
    I just saw another post that said this tv does not get reception since the digital reception. Do you have one and know for sure? Thanks for your input.
  • 2,071 Answers
Curtis is a digital LCD TV .All LCD TV is a digital function already.
Hope its help:
Regards:
VOTIT
Posted on Jun 27, 2009
  • LORETO LACARON
    LORETO LACARON Jun 27, 2009
    This unit is not good for pick up a good reception.You need more antenna to connect to pick up a good reception.
Do i need to have the bose system turned on in order to watch tv or can i have the cable box bypass the bose receiver? I do not wish to use my bose for everyday tv. Thanks
If your TV has its own speakers you don't need to have the Bose turned on for Lo-Fi watching. Not knowing what your TV has for analog and digital inputs or your Cable Box has for analog and digital outputs...
The LS V20 has 3 analog inputs plus a Tape Loop, so you could have the Cable Box (not the TV) audio; and two (or three using the Tape Loop) other analog sources. NOTHING should need to route to the TV first. The Bose should get the audio from whatever you're watching directly from that source.
If the Cable Box has only one analog audio output available but the TV has a digital one
Since an analog audio output can be split you could 'share' the cable box audio with both the TV and the Bose. Digital audio may also be possible between the Box and the TV.
Jan 10, 2011 | Bose Lifestyle V20 System - black Theater...
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
Guide
This TV is analog, meaning there are no "straight digital" inputs, and the tuner itself is NTSC (analog), and not ATSC (digital). You will need a digital converter box to receive over-the-air (broadcast) digital television stations. This does NOT, however, preclude you from purchasing Digital Cable or Digital Satellite, and using the analog output on their converter boxes. The television will display high-definition images from those boxes and other sources.
I have the owner's manual in .pdf (adobe acrobat) format. Leave me your email address and I'll send it to you.
Thanks,
Rob
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Want analog local tv, but getting digital response
You can't receive analog signals with a digital tuner so you are stuck with your 5 in. Sears TV
Mar 05, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Curtis RT700 7 in. Portable Television Logo
251 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
