Question about Boating
How to splice cables for my fish finder
Mice chewed through the speed, temp. and the tranducer cables of my x65 lowrance.
  • 86 Answers
Man, As much as I hate to say it, you need to call up Lawrance and order a new one. I have tried but have never been able to repair cut transducer cables.
Posted on Aug 07, 2009
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
LOOKING FOR MANUAL LOWRANCE X65
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/X65.pdf
May 23, 2011 | GPS
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Problem with interference lowrance x25fishfinder
Transducer will stop getting readings if it gets air under it. If it's lower surface is too much above or below the bottom of your boat, this can happen.
Apr 05, 2009 | Boating
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Feb 25, 2008 | GPS
Boating Logo
116 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
