Question about Canon PowerShot SD1100 IS Digital Camera
Trying to charge battery using usb port on laptop. the camera won't even turn on. prior to now when turned on it would then immediately turn off, battery so low. can i get it to work via usb? lost electrical plug.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Sadly this doesn't always work, especially (and perversely) when the battery is in a very low state to start with. You need a mains lead, I fear.
Posted on Jun 27, 2009
Camera turn off USB plugged in laptop to charge ( first charge) the battery, SD class 10 HD card installed, now charging light goes on for a very short time and then goes off . as in fully charged. wh
A better that came with a new camera, most of the time is not defect. Please charge it at least 2 times, before you say it is defect.
If possible, use an external charger, because not all USB ports on a computer can deliver 5 volts and 500 mA (Ampere)
Oct 25, 2014 | Vivitar Sakar - DVR785HD-BLU - Blue 5MP...
I barely got this camera. It wouldn't turn on so I
What make and model camera?
Not all USB ports put out enough current to charge a battery. If you're connecting through a hub, try bypassing it and connecting directly. If you have another USB port, try that.
Apr 26, 2013 | Cameras
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
My camera won't turn on unless connected to the computer
Change the port of the usb at your laptop. Maybe you have to change the usb cable,sometimes comes wrong at factory,or maybe teared.try to change another cable.
Mar 16, 2012 | Vivitar ViviCam V15 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
My Flip Camera Model U2120 stopped turning on. If I plug it into the USB port the screen lights up and says "Connected". Once I remove it then try to turn the camera on it still does not work. I...
I found some interesting information about your camera. It turns out that the camcorder will only charge its battery if it detects the physical presence of its rechargeable battery pack. Battery detection depends on two physical components. One is a switch located at the top of the battery compartment, The other is a little plastic tab included with the battery pack
Instructions for the fix are located at this link: Fixing Flip UltraHD that won charge its battery
Jan 03, 2018 | Pure Digital Flip UltraHD U2120 High...
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
I am trying to charge the camera battery through my pc
The camera does not charge the battery through the USB port. Connecting the camera to a computer drains the battery faster, as the camera has to use juice to communicate with the computer (even if only to say it has nothing to say). Please use the supplied battery charger or a replacement.
Jan 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
