Question about GE Supermicro X6DA8-G E7525 EM64T S604 Dual Xeon PCI-Ex/SATA/DDR/U320/EATX Mainboard (MBSMX6DA8G) Motherboard
Supermicro x6da8 won't post. Can't get into BIOS either.
Supermicro x6da8 won't post. It gets as far as successfully checking ram, cached SRAM passes, then it says System BIOS shadowed, then Video BIOS shadowed, then stop right there. It won't go any further, and cannot get into the BIOS.
  • 64 Answers
Disconnect all power connections to the board and take the battery out for a few minutes and then put it all back and see if you can acess the bios. If you still cant, try a bios flash and if that brings you no joy, board is done
Posted on Jul 11, 2009
Supermicro system initializing
The POST process is documented in the user manual under BIOS Post Codes.
Jan 31, 2013 | SuperMicro Computers & Internet
X7DBI+ bios password
Hello here is the homepage:
http://www.supermicro.com/products/motherboard/xeon1333/5000P/X7DBE.cfm
Remove the cmos battery on the mainboard for like 15 min. and inset the battery again.
This will clear the bios and remove the password.
But you have to setup the bios clock, date, boot settings, when the pass is gone.
The cmos battery look like this:
Please take antistatic precautions when working on the maniboard.
Good luck
Jan 12, 2013 | SuperMicro X7DBi+ Motherboard
Supermicro x9dai won't post, beep, boot or much of anything else
this motherboard won't work with latest v2 cpu's from intel , until you upgrade your bios to 3.0 version.(you must plug your 8pin conector for cpu's , both of them !!!!!).So you must start the mb with an older cpu , then upgrade bios .
Dec 08, 2012 | SuperMicro Computers & Internet
Supermicro x8sax memory bank issues
The X8SAX motherboard has 6 memory slots. Try booting with one memory stick in each slot to identify which memory bank (dimm slot) is giving you issues. If you are able to boot off of a good slot, check the BIOS version to make sure you have the latest installed (R 2.0b). It can be downloaded here: Super Micro Computer Inc Products Motherboards Xeon Boards X8SAX
If you are unable to get into the BIOS at all, check the warranty status and submit an RMA request to Supermicro:
http://www.supermicro.com/support/rma/
Mar 01, 2012 | SuperMicro Desktop Board - X8SAX...
SuperMicroX6DH8-xg2 no POST beep no Video I remove RAM and reseatd RAM but still no POST
If it's 1 long and 2 short beeps it's a video controller error. Check the warranty status and RMA if possible: http://www.supermicro.com/support/rma/
If it's 1 repetitive long beep, it means that no memory is detected. Try booting with only 1 stick of RAM. Try different dimm slots to see if you can isolate the issue. You may have a few modules that do not want to work together, a bad stick of RAM, or a defective dimm slot.
Mar 29, 2011 | SuperMicro X6DH8-XG2 Motherboard
The vga doesn't work
You need the latest drivers to make sure there are are no problems & you can download them from
http://www.drivers-updates.net/drivers/motherboard-drivers/SUPERMICRO-Motherboards-drivers.html
The only other reason is hardware failure for which there is no other solution but to use a separate graphics card on a PCI slot of the motherboard to get proper display.
The last option would be to change your motherboard.
Nov 29, 2010 | SuperMicro X6DA8-G2 Motherboard
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Where do I get raid drivers for Supermicro x7dal-e+ MB
you can find the drivers you seek here...www.supermicro.com/support/Bios good luck!
Dec 18, 2009 | SuperMicro X7DAL-E Motherboard
GE Supermicro X6DA8-G E7525 EM64T S604 Dual Xeon PCI-Ex/SATA/DDR/U320/EATX Mainboard (MBSMX6DA8G) Motherboard Logo
561 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
