Question about Samsung PS42S5H 42 in. HD-Ready Plasma Television
Images are too big for screen, can't see scores on Sansung HDTV
HELP, we have tried all the menu settings
    Sniper:
  • 56 Answers
The tv needs e/w correction check pin -cution ckt properly most dry solder is possiblity
Posted on Jun 27, 2009
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    Trying to change tv format on my dynex 32 LCD
    You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
    Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
    Picture doesn't fit on my Samsung HDTV
    after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
    Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
    Picture is too big for the screen
    go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
    Thanks for using FIXYA
    May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
    Image too big for screen
    I have the same tv.
    On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
    Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
    Vertical lines on sansung hln5065w tv
    Bring up the on screen menu if you see the lines in front of the menu replace the DMD board.
    Feb 19, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
    Samsung PS42S5H 42 in. HD-Ready Plasma Television Logo
    232 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
