Question about Maytag MGC5536 Gas Cooktop
Igniters on my Maytag gas cooktop do not spark
The four igniters on my Maytag Gas Cooktop Model CSG7000CAB S/N15764099SY stopped sparking. The first time this happened was a week ago, but then they started working again. This time they appear to be dead.
Is that something I would need a servicemen to fix, or can I buy the part(s) and replace it myself?
    Novelist:
  • 222 Answers
U nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
Posted on Jul 04, 2009
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
Maytag/Jenn Air JGD8130ADS one burner will not ignite but all others will. solutions?
Turn off gas. Remove the cartridge and remove back cover. Clean the ignition spark area. Re-install the cartridge without the back cover. Try to ignite the spark. If the spark works. The spark wire is too close to the back cover. Use an electrical tape to insulate the wire from the back cover. Other swap the two spark to see if you have a faulty spark.
Jan 02, 2012 | Maytag JGD8130ADS 30 in. Gas Cooktop
How do I convert my maytag CSG7000CAB gas cooktop
i NEED TO DO THE SAME TO MY MAYTAG COOKTOP DID YOU FIND THE ANSWER YET?
Mar 08, 2010 | Maytag MGC5536 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Igniters will not work
did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Dec 24, 2007 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
Open Questions:
Maytag MGC5536 Gas Cooktop Logo
525 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
