I have a compaq presario F700, I lost the charger and just buy one universal, is plug in but it shows that is not charging, What i should do?
    President:
  • 2,559 Answers
Replace the charger with the correct one.
Posted on Jun 27, 2009
Battery/charger
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Exclamation mark by network adaptor f700 presario compaq laptop
You can download the LAN and device drivers from theCompaq/HP WEB support/download page. Make sure you select your model laptop andthe Windows drivers you require and install them. Click on this link todownload the drivers: -
www.compaq.com/country/cpq_support.html
Feb 05, 2012 | Compaq Presario F700 Series Laptop...
CAN I USE A DIFFERENT ADAPTER TO CHARGE MY LAPTOP
There are aftermarket adapters that can be purchased cheaper than the ones provided from the manufacturer. Unfortunately, there is no standard for notebook charging adapters. This means there are many different adapters available, with differing plug sizes, voltages, and current ratings. Having lost your adapter makes this a problem, as you cannot get the information from the adapter. Go to the manufacturers website and see if you can find the specifications for the adapter. Output voltage, current, and plug polarity are the three important items to verify. You can use another adapter if the voltage and polarity match. The current rating is less critical, but should not vary from the manufacturer's specification by more than +/- 10%. Too little current rating will overheat the charger, too high may cause the battery to take charge too quickly and it could overheat.
Jan 01, 2012 | HP Compaq Presario F500 F700 and G6000...
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
IT CAN BE FIXED.. HANDS ON IS THE BEST WAY . LETS GIVE THIS A SHOT. COMPAQ NOT GOING TO HELP YOU THEY WANT YOU TO BUY ANEW ONE IF IT WORK WHEN IT HAD VISTA , IT WILL WORK NOW, I AM SURE OF THAT. YOU MIGHT HAVE TO HAVE IT COMPLETELY TAKEN APART AND RESET IT , BUT THATS ANOTER STORY , FOR now remove the battery and remove the ram/ memory card, then remove the hard drive , a sigle screw should remove the hardrive memory as well then i want you to hold down the power button for about 3 minutes , then insert harddrive only press power, if you hear a beep good sign if th power button remains after the harddrive is installed, hold power button till computer turns off then install ram memory USE YOUR POWER CORD THREW OUT THIS PROCESS freddiemccly@yahoo.com your computer can be fixed i know its easy said then done ITS MINOR but a tech will tell you the total opposite
Jun 02, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
