Question about Marantz CDR-300 CD Recorder
I recently purchased a used Marantz CDR300 CD Recorder. Everything powers on but when I put a cd in the tray, it doesn't close automatically when I press the close button and when I manually close it, the lcd reads "CDR Error". Does this item need to be repaired? Thanks for your help or referring me to someone who can assist me! Sincerely, Ken
  • 2,071 Answers
CDR error means the trouble is in the laser eye,maybe the eye is faulty already or dirty. If the laser eye is dirty,then you need to clean it with a cotton buds.Open the unit then wipe the laser eye tenderly with the cotton buds or buy a DVD / CD cleaner kit.Just click this link;
http://electronics.bizrate.com/search__SEARCH_GO--GO__SEARCH_GO.x--36__SEARCH_GO.y--16__keyword--dvd+lens+cleaner__search_box--1__sfsk--1.html
Hope its help:
Regards;
VOTIT
Posted on Jun 27, 2009
Cd tray for marantz cdr631
Buy a second hand one and use it for parts.
Mar 25, 2015 | Marantz CDR631 CD Recorder
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
Is there anything in particular I need to do to use the digital outputs of the Marantz pmd340? My ps audio dac works with a rotel cd player automatically but I can not get it to work with the marantz with...
You may have indicate on the CD player that you wish to use the Optical output and then even when that is correct there are different bit rates that may not be compatible with the input of the amp.
Dec 26, 2012 | Marantz PMD340 CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Marantz 300 C.D recorder no signal/tons of static on recording
your set is damage due to static there are lots of tech in your area look into fixya directory and you will find a tech close you.i recommend that you purchase a new set to repair it will be costly. good luck.
Apr 10, 2009 | Marantz CDR-300 CD Recorder
Marantz: Rereading ..... error
Put a lens cleaner into it for the first troubleshoot.
Aug 07, 2008 | Marantz Audio Players & Recorders
Marantz cdr300
try turing off opc in menu see if that helps use hi end meadia only memerex i like
Jan 18, 2008 | Marantz CDR420 CD Recorder
Marantz CDR-300 CD Recorder Logo
503 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
