Question about Jenn-Air JCD2389G Side by Side Refrigerator
I have a JCD2389GE side-by-side and the refrigerator side is not cooling.
  • Jenn-Air Master
  • 4,654 Answers
The most likely problem is the Adaptive Defrost Control Located in the fresh food compartment behind the control panel #13 in photo below. Part number for the ADC is 61005988 and the photo is in the top right corner of my web page. Click on photo to see price and order. http://servicepartstec.blogspot.com/
Any questions, let me know, Thanks, Sea Breeze
Posted on Jun 27, 2009
3 Suggested Answers
tech master
  • 120 Answers
SOURCE: I have a JENN-AIR side-by-side
the damper on the left corner in the refrigeartor is not opening is either blocked with ice or broken also when the frezeer is not defrosting like it supost to it blocks air circultion to fresh food section check both thing damper and defrost
Posted on Nov 10, 2008
EllaWatson25
  • 725 Answers
SOURCE: refrigerator not getting cold, its cool, the
This is probably a bad defrost system. This happens every once in a while. If you 'll call or emailus, we'll be sure to get the proper parts out to you right away to get you cooling again soon and get you ready for Thanksgiving. It's just around the corner you know? We hope to hear from you real soon.
Posted on Sep 30, 2009
How do i replace the water filter
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2389GES/1266/0165000
Nov 13, 2014 | Jenn-Air Refrigerators
I have water leaking from the bottom. I turned off the water in the back and the problem stopped. Where is the water most likely coming from and how can I repair it? Model #JCD2389GE
Hello
Suspect your main water inlet valves .Usually ,they are behind kick panel bottom front of machine.Look for two small solonoid valves with tubing attached and inspect for leaks.Unplug machine to make repair,there is 120 volts down there.
Hope this helps
Sep 05, 2011 | Jenn-Air JCD2389G Side by Side...
Ihave a jenn-air model #JCD2389GE the fan is running but the compressor won"t kick on it clicks and there is a short power surge but it does not turn on
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | Jenn-Air JCD2389G Side by Side...
Refrigerator not getting cold, its cool, the condensor fan is clean, freezer ok. Does refrigerator side have fan model #jcd2389ge
Sep 30, 2009 | Refrigerators
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
I have a JENN-AIR side-by-side refrigerator Model # JCD2389GE. The freezer side works great but the refrigerator side barley gets cold. Help!
Nov 09, 2008 | Refrigerators
JCD2389GE Fridge Lock Button Is Lit
Solution found! I located manual on line. If anyone else has this problem, press the "lock" button three times in ten seconds! I'm a genius!
Jan 27, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
682 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
