Question about Seiko 5 Automatic Light Cream Dial Watch for Men
Hi ! Why my Seiko automatic ( cal.7S26A ) does not respond to my time adjusting ? Balance and a spiral are in perfect condition, the watch was properly cleaned. Thanks ! Erik
  • 2,071 Answers
Even you wind the crown the hands not moving or not responding? If this the case then the trouble is in the clutch wheel .Maybe the gear is already breaks thats why it will not respond.
Feel free to ask whatever the results.
Hope its help:
Regards:
VOTIT
Posted on Jun 27, 2009
I cant set the arm time
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
Dec 26, 2015 | Watches
My seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
Feb 28, 2011 | Seiko Watch SNXJ89K1
I have a Seiko Cal.7T32 which has served me most efficiently over a number of years now. However it has developed a most mystifying problem... perhaps over a week duration it will once or twice quite...
As you have had the watch for "a number of years", have you had it serviced? Sieko recommend servicing every 2-3 years.
If could be that cleaning and adjustment are needed to put it back in good order.
(I don't know the details of your watch but on the assumption that it has a balance wheel, since this is a rapidly moving part, it can suffer wear and need periodic adjustment.)
Go to thier web site http://www.seikowatches.com/ to find the location of your nearest service center.
Jan 10, 2011 | Seiko Watches
How do I adjust the day of the week on my Seiko
Hello Bob, Mike D75 here, The day of the week can be changed by pulling out the stem to set, every second time to 12"Oclock--2 O'Clock will cause the day to change.
May 28, 2010 | Watches
Hi.ive own a 70s seiko diver 6309-7040 an problem is now the watch is not keeping time (slow at least 5mns a day)can i do DIY adjustment on it..pls helpguide..thanks.
As thesed watches are sealed it is unwise to attempt any DIY activity.
As you have had the watch for many years it is very likely that it needs a clean. As it is so old, some parts may need replacing and this can only be doneby the maker. (Most makers recommend cleaning every 3 years or so).
If it is only just starting to loose time, then you have done very well out of it!
May 22, 2010 | Seiko Divers Automatic watch
I have automatic seiko 5 watch and is gaining time ; so how do I adjust so that it becomes accurate
If you want to do it yourself, be ready that your watch can be damaged and will need serious repairs. Here is how to do that: Open the watch case back. Lay it face down on levelled surface. On the balance **** you will see the index with - and + markings. Using fine pointed tweezers to move the index towards - sign. Do it very carefully, almost invisible to the naked eye. Just very slight touch of index can change timekeeping significantly. If you are not sure what you are doing - visit your nearest watch repair shop and ask to adjust your watch.
Rate me, plz.
Jan 23, 2010 | Watches
I purchased a Seiko divers watch in Canada approx 25 years ago. It had an English-French day wheel. Unfortunately the interior became damaged beyond repair. The case and strap remain in perfect condition....
You could ask Seiko via their web site. If this watch is of value to you, send it to their service center for repair. They can fully advicse you as to the cost and other factors important to you. Go here: http://www.seikowatches.com/support/faq/repairs.html
Jan 15, 2010 | Seiko Divers Automatic watch
Time / date adjuster on my Seiko SNAA63 falls out
Sounds like the mechanism that hold the adjuster in is damaged, im afraid you'll have to get it fixed again
Jun 18, 2009 | Seiko Chronograph SNAA63 Gents Watch
Where can I find the pictures : how to install the movement for Seiko dial 7s26b ? Please help how to install the balance wheel to balance stud bridge?
there is some videos on you tube but is a difficult work!is the same with all the watch calibers!you need special tools microscope and experience.in the end if you put everythihg in correct you have to adjust the hairspring to keep the correct time!enother special and expensive timing tool!
Dec 02, 2008 | Seiko SKA098 Wrist Watch
Seiko 5 Automatic Light Cream Dial Watch for Men Logo
617 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
