The car was fine when I started it and halfway to our destination, it began to make a strange whirring sound and the battery light came on. It starts without a problem so it has to be something else
SOURCE: How do you change the battery on a 2006 dodge stratus?
is it unde rthe tire ? front my my serbing or can u get to it under hood ? if its tire one u hav eto remove fornt left tire take out platsi stuff then thers batter behind wall k thx nick
SOURCE: 2006 Dodge Caravan Engine Light Blinks 10 Times & wont start
It sounds like your starter needs cleaned or replaced. The poping noise could be the actuator not engaging right. As for the engine light, it could be just a coincidence.
SOURCE: 2001 Dodge Grand Caravan. has been making a loud
MOST LIKELY HAS A PLUGGED TRANSMISSION FILTER.
TORQUE CONVERTOR CLUTCH FAILURE COMMON.
CHANGE TRANSMISSION FILTER AND ROAD TEST.
IF NOISE IS GONE AND RUNS NORMALLY, CHANGE TORQUE CONVERTOR AND RESEAL TRANSMISSION.
SOURCE: 1997 Dodge Stratus- When headlights on other dash lights go off.
Check cluster fuse, instrument panel fuse.
