Question about Samsung HCJ652W 65" Rear Projection Television
I have a Samsung HCL652W, the convergence is way off and I am unable to adjust it enough to make the picture viewable. It looks very 3D. What part would need replaced to fix this?
  • 1 more comment
  • kcchiefs384 Jun 28, 2009
    No the TV has not been violently moved recently. I was fine one minute then not. I had been acting weird, my kids would jump on the floor and it would go normal again. It hadn't done that in a month or so. What size is the magnet? I did not know rear projection TVs had magnets. The remote has no affect and neither does change the input method.
  • kcchiefs384 Jun 29, 2009
    Thanks for the idea, unfortunately it didn't seem to change anything. I had left it unplugged since Sunday morning, I just checked all the connections, none felt loose and then powered it up, still looks very 3D. When I run the perfect focus function it doesn't get past the red test. I attached a pic of the screen, not sure if it will help. Could the convergence board be bad?
    sure if that means the red is the issue or not.
  • Rich Elliott
    Rich Elliott May 11, 2010
    It sounds like you have lost a magnet of one of the CRT's. Has the TV been moved violently? Does the remote have any effect?
    Champion:
  • 205 Answers
True convergence problem. The crt's use electromagnets and magnets for alignent of the electon beam. Magnets are physical alignment and the electro magnets are vis remote. The kids juming is a key element. I would suggest unplugging the tv and let it set 24hrs to discharge. Discharging the tv is critical. The picture tubes hold a significant charge and should be respected!!
What you are describing is a loose or marginal connection. Kids jumping is like slapping the side shocking the loose connection. I would pull the back cover, and OBSERVE the electronic connections around the yoke of the three CRT's. Keep hands away from larg diameter cable near the projection side of the tube. (large end) If you know what color is drooping, close inspection of that tube connections compared to the others would be a place to start. While the back cover is off consider blowing the dust out eliminating heat build up, and wiping the optics before reinstalling the cover. Let me know
Posted on Jun 29, 2009
Unable to adjust red convergence much red shadowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Philips 60PP9202 60" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
The picture arced and looks 3D. Plus the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Picture on screen shrunk to about half size and color bands go around the picture - red, yellow, green, blue - almost looks like things are in 3D
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 22, 2010 | Apex Digital GB43HD09 43" Rear Projection...
I have a 65' Samsung model #HCN-653W rear projection tv... just recently the picture became distorted as if watchingsomething that is 3D... Is it a tube or something that I can replace with out getting to...
  • Screen looks 3D
Feb 23, 2010 | Samsung PCL541R 54" Rear Projection...
Double image and 3d color
  • Screen looks 3D
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Double vision dropped to the left about a half inch and a lot of red tone.
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Oct 17, 2009 | Samsung HCL652W 65" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Convergence
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
HCL652W
Your convergence ICs are defective and quite possibly the burning smell was likely some of the convergence Resistors burning. Its actually not that exspensive of a repair. you can get a brand new Sub deflection board for your set for 232.00 at the following link and that will fix your set and you just put the new board in. The site will also provide you with free on line tech support to assist you with installing the new board. you need the P54 Sub deflection board. Its available at the following link.
http://servicemanuals.vstore.ca/
Jun 13, 2008 | Samsung HCL652W 65" Rear Projection...
Samsung HCJ652W 65" Rear Projection Television Logo
193 people viewed this question
Jerry Greenberg
Jerry Greenberg
