My machine is showing codeE240.this happened after serving the machine
SOURCE: My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
SOURCE: SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
SOURCE: My sharp AR5516 copier shows CH error code
side door open , flashing means td cartridge not installed
