Question about Dell E173FP 17" LCD Monitor
Dell E173FP temperature sensitive 17" monitor
Hi
I have a temperature sensitive dell E173FP 17"monitor. I want to replace the inverter/power supply board. It takes 2 different kinds, one a 2 connector CCFL lamp board and one a 4 connector. Is there a way to tell what board I have without dismantling it? Thanks for your help.
avstan
  • avstan Jan 08, 2008
    Thanks for your response. Your directions were very helpful.
    avstan
  • 25 Answers
No. The best way is to take off the rear panel and insulator cover. Look on the board for "p/n: xxxxxxx" for the exact part number. I've found this to be the best way to ensure the correct board.
Also, once you're inside, you could see how many CCFLs you have.
Posted on Jan 08, 2008
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
I have adell monitor which bliniking with green light when pluged into power what could be the problem?
Please look here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
You need to check the fuse, transistors, capacitors in the inverter/power supply board.
Replacement board: http://www.lcdrepair.us
Post back what you see inside so I can guide you further.
Apr 06, 2010 | Dell E173FP 17" LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
When I connect the power to the monitor Dell E173FP 17, power bottom commence to turn on and off repeatedly...
Power LED is turning on and off because the power supply is in shutdown-restart mode becuase it sensing over current draw, it can be bad caps in power supply, shorted tramsistors (c5707) in the inverter circuits. See pictures: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Check the fuse and the transistor out (check Emitter and Collector pin for short circuits)
Mar 04, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPs LCD screen (4 years old) is blank, power button is blinking green. I have read numerous articles about the same problem on similar models (E173FPc?) caused by poor solder connections at...
Replacing transistors would be the last thing in that troubleshooting. First, check all electrolytic capacitors if there are any of them "bubbled", replace those. Next, if there is the fuse used for supplying DC voltage to the inverter area, take it off and check if LED will still blink as before. If there's no such fuse, you can cut the trace, supplying DC voltage to the inverter, another words, you need to unload inverter from power supply and check LED behavior then, if it will stay steady, then next steps will be to troubleshoot the inverter, otherwise, using ohmmeter ring all capacitors and diodes in the power supply part, especially connected to PWM chip at primary side of pulse transformer. By the way, what kind of chip is there?
Apr 05, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
No Power
Hi...there,
No, power.. Could one things, your backlight inverter are burnt out. Need to replaced a new inverter or repaired it.
Oct 11, 2008 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Has power but no display
Do the flashlight test. Shine flashlight on front of screen at angle and see if you can see an image or lettering. If so, it is probably inverter board. Let me know first if you have an image.
Jan 29, 2008 | Dell E173FP 17" LCD Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
240 people viewed this question
Alun Cox
