Question about Garden
Lawn mower wont start
Hi i have a tv540sp lawnmower and am looking for an instruction manual
I recently got this and think that there are some springs missing from choke which may be stopping it from starting
There is a spark and petrol in the tank and it primed ok.
I need to know the start sequence and also any trobleshooting measures please
  • geoffJ Aug 13, 2009
    Hi
    thanks for the reply.
    After a couple of hours of checking things out I eventually found the problem.
    Stale Petrol - this mower had stood for some time and the petrol had gone off one I emptied the tank and fed new fuel in off it went as has continued.
    For you problem remove spark plug and touch it to the cylinder head and pull cord and see if a spark if not then possibly the magneto
I have the same mower and I have the choke assembly complete, I will take a picture for you if you want to show you what should be there? Mine wont start at the moment wondering wether its the magneto
stu
Posted on Aug 13, 2009
  • saw81 Aug 13, 2009
    Thanks for your reply to, like yourself I (funnily enough) did what you said before reading your comment and found out that the engine brake cable is so loose that its not pulling the engine brake lever on the engine enough to enable the magneto to work, hence no spark. So trying to find a replacement engine brake cable with no avail.
Lawnflite 630 ride on mower. Key to turn how do we start the engine?
hi,
did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
Jul 31, 2017 | Garden
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
Kubato 1760
Hi karen. Your not explaining what you have done to get the mower going. All petrol mowers run with three problems. Fuel,fire and air. If you are getting all three it will either be a snapped Piston or the gaskets on the block have perished. Check eHow's website and follow the instructions. Good luck
Jul 05, 2013 | Briggs & Stratton Briggs Stratton...
Rover QuantumXTL 50 mower wont idle
clean the carby or could have bent governor arm where spring goes
Feb 03, 2013 | Briggs & Stratton Briggs Stratton...
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
Toro personal pace lawnmower recoil spring broke
Go to www.youtube.com and type in fix starter spring lawnmower in Goggle.
Feb 28, 2012 | Toro Power Lawn Mower
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
My lawnmower won't start
My first action would be to check for fire. Pull the spark plug wire and either snap an extra plug onto the wire, or pull the mower's plug and snap into the wire. Pull or try the key start, to see if the plug is firing.
If it's not firing, you'll have to look at other possibilities... eg kill switch or coil issues.
I hope this helps... Good luck!
Oct 22, 2009 | Garden
Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
May 09, 2009 | Garden
Garden Logo
215 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
