Question about Sony XM-404EQX Car Audio Amplifier
I've been given one of these amps by a friend. There's a slight problem with it though, the front rht input is far more sensitive than any of the others. It's as if the gain is turned to the max on that input only. I don't know the units history but everything else seems ok. Any ideas? Cheers Tony Australia.
  • 44 Answers
If the other channels put out only a small amout of sound compared to the rh channel it is possible that the preamps might be buggered. To test this get one set of outputs from your headunit and connect them to each channel one by one and the same on the output side with a speaker. If the problem doesnt exist then, it could be your head unit that is at fault. check the settings in your head unit as well you might have accidently changed the fader settings.
Other than that drop it in for a quick bench test at a local car stereo installation place and they should be able to offer a quick and cheap if not free diagnosis of what the issue will be.
Posted on Jun 27, 2009
  • mutleysdoo Jun 28, 2009
    if it is easy for the tech to diagnose the faulty component, and get the replacement part I dont think you should get a very high labour cost as it should be a realively quick fix. all the best mate.
    Just make sure you get a quote on repair first before committing to it as you may find it more benificial to get a new amp.
    good luck mate
Cheers mutleys. I've not installed it yet and am bench testing it with an i pod as source into the phono inputs and similar speakers into all of the outputs. I suspect that there's a problem with a gain transistor in the pre amp stage of that particular channel but I'm no expert. As all of the gains and equalisation pots work and the volume is there I hope that it can be fixed cheaply, I was hoping to use the front and rear outputs in bridged mode to give 80 rms into 2 channel driving some big old Pioneer 3 ways. It'd be a pity to junk it.
Tascam 122 Mk III - input signal is low and distorted
It is hard to guess what is causing this but for all of the gain to be reduced like that either the deck has seen some really high input signal in the past that blew out some amplifiers or that there is a power supply component that has taken the input electronics down.
I suspect that you will need to have a Technician look at it. If you are near Chicago, I may be your answer, I have been working with these Teac units for 40 years and was a Lead Tech at Chicago Factory Service in Arlington Heights.
I can be reached at skywavebe@sbcglobal.net
If you are far off- I have other people that can do the job one in New Jersey and a few others.
Aug 14, 2012 | Tascam Audio Players & Recorders
One cylinder fires intermittently
Run a cylinder leak down test
Mar 04, 2017 | Yamaha Motorcycles
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
The center channel is not working. according to the color of the plug that goes into the amp from the speakers. what color goes to which speaker?
Get the manual free...
http://www.retrevo.com/support/Sony-RHT-G2000-manual/id/11167dj888/t/2/
Um, this product doesn't use color coded or proprietary speaker wires nor does it have a connector for Center, which is built into the stand as well as the front speakers.
Jul 13, 2011 | Sony RHT-G2000 System
TOUCH SCREEN TOO SENSITIVE KEEP MAKING CALLS WHEN I ONLY WANT TO SCROLL DOWN SCREEN
Hello Eda,
You can resolve the problem by increasing or decreasing accuracy on the keyboard. Press MENU on the Home screen > Settings > Language & keyboard > Touch Input > Text input > Calibration tool. Tap the given phrase and after you have completed the calibration, the keyboard should be more attuned to your touch screen habits.
Jun 18, 2011 | HTC Wildfire Cell Phone
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
Amp is on but wont work...please help!!
Hello lillj2323,
OK, you say that the amp won't get your RF Punch's to pound. You do not say if you get any output at all. So let's start from the beginning.
The KAC-X542 is a multichannel amp with 2 sets of stereo outputs, 1 set of stereo outputs and 1 bridged connection for sub(s), or 2 bridged connections for sub(s).
Make sure that both 30A fuses just to the left of the power connections are good.
Check that the "ID number" is set to "0". Make sure that you have RCA inputs to both channels A and B (leftmost pairs of jacks). Your subs should be connected to the 1st (+) and 3rd (-) of each set of output terminals.
Make sure that there are no broken off plugs or pins in the jack marked "H/U Terminal" or either of the 2 jacks marked "remote".
Check that the amp is set up for 2-channel bridged. The 6 switches below the filter controls and the filter pots should initially be set:
1 - Middle position (off)
2 - Up position (on)
3 - Down position (off)
4 - Up position (mono)
5 - Down position (off)
6 - Up position (mono)
The pots should be set approximately:
LPF - minimum
HPF - maximum
Input Sensitivity - match your head unit - probably between 1 - 3
HPF - maximum
After you get the speakers working, the LPF, HPF and Input Sensitivity can be tweaked for best sound and lowest distortion.
Hope this helps.
Apr 17, 2009 | Kenwood eXcelon KAC-X542 Car Audio...
Sony XM-404EQX Car Audio Amplifier Logo
94 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
