Question about Canon PIXMA iP6700D InkJet Photo Printer
Dismantle canon pixma iP6700D
Am attempting to remove casing of iP6700D and managed to get as far as the final move to release the main top section by following the arrow release symbols except for the right hand corner.What am I missing (apart from know how?) Appreciate some guidance, Thank you.John.
    President:
  • 2,306 Answers
Inside the front opening there is another arrow, the back corners either have screws, or plastic tabs. If there's a gear to support the scanner, there's a screw behind that assembly.
Posted on Aug 07, 2009
  • Jan Dec 19, 2010
    This answer was not speciific for the IP6700D. This one is: The fourth (missing or overlooked) arrow is on the front of the cart reader, at the right side and pointing to the left. That means that you have to poke on that height, but in the left side of the cart reader section! If anyone is interested, let met know: janfop@kpnmail.nl. I can send you some pictures if you like.
    pommyjohn696: still need it? PS: it took me about five hours and a sleepless night to find out.
My Sceptre x32 tv turns on normally, but the picture begins to flash on and off repeatedly. volume is not affected. I've tried several reset methods, but nothing has worked so far. Any suggestions?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 05, 2016 | Sceptre Televison & Video
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Proper heating problem
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Jan 07, 2011 | Samsung MS840 800 Watts Microwave Oven
When I turn on my MP830 Cannon the error "release the scanner lock switch and turn the power off and back on" appears. I have done it . The scanner appears to attempt moving, but does not get very far
hello, what i have found out so far, sometimes a small bit of tape they use on the scanner and ribbon cable rubs on glass, then catches on the white calibration area, but not all the time, when a machine has been used really well, and taken care of, the scanner just fails, replace whole top unit, not the doc feed, just scanner unit only, if main pcb still good machine will work just fine
Sep 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
How to increase memory for sms
i only get 178 msgs on my w700i. so hw to increase the memory capacity of my cell???
Dec 05, 2007 | Sony Ericsson W700i Cellular Phone
How to open case of Acoustimass module
Just a bit more info...a bit more detail
Remove the two screws from the case at the back.
Sit the unit in normal upright position. Use a good torch and look at the back of the unit along the top seam where the plastic case joins the main body - there are three latches to disengage along this seam.
1. The thumbwheel which turns to the left & exposes the tab. This disengages a simple Tee'd section on the wheel which stops the case sliding down. As long as you can see the tab this is disengaged.
2 & 3. On the far left & far right of the seam are simple lever latches which must be pushed back towards the main body to allow the rear case to slide down. Push these in then the case will slide down quite easily.
Sep 01, 2007 | Bose Acoustimass 15 System
Canon DC100 - Finalizing Problems
thanks I got it plug-in the camcord to the wall outlet with DC adapter then you can start the finalizing thanks again
Dec 30, 2006 | Canon DC100 DVD Camcorder
Canon PIXMA  iP6700D InkJet Photo Printer Logo
269 people viewed this question
old marine
old marine
