Question about Magnum S9 Base CB Radio
My S9 won't stay on frequincy. When i key the mic the frequincy just takes off and runs randomly of on different frequincies. Where can i find a good playce to send it to be repaired? Buzz
    Champion:
  • 219 Answers
Send it to Magnum Repairs At 4055 Guasti Rd Suite 101 Ontario Ca 91761 Call first 909-390-5056
Posted on Nov 21, 2009
Could somebody tell me if this TV will work in Argentina? LG - 42'' Class / 1080p / 120Hz / LCD HDTV Thanks
Yes,u buy this tv in the US?Argentina run on NTSC frequincies,the tv should work find.
Jun 08, 2010 | LG 42LC2D 42 in. LCD HDTV
IS IT DELL 2606C TV LCD WORKING ON PAL SYSTEM?
U bought it in Euroupean,Asia countries?Yes,it will all those regions countries run on PAL frequincies.If u bought it in the US,Mexico and Canada.No the tv will not run on PAL or any PAL devices.The US,Mexico and Canada run on NTSC and NTSC devices only.
Jun 01, 2010 | Dell W2606C 26 in. HD-Ready LCD Television
Will a Tv bought in England work in Spain?
Yes,all EUROUPEANS countries wil work with this tv it run in PAL frequincies.Also ASIAS run in PAL.Not the US,Mexsico and Canada run in NTSC frequincies.
Jun 01, 2010 | LG 32LG30 32 in. LCD HDTV
Frequincy changing
press and hold the + button untill the frequency changes then move up and down to the one you want.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 25, 2010 | Motorola Talkabout T5800 (22 Channels)...
2000 jetta tdi car start and stop immediately there is a key sing light in dash any idea what is appening
It could be a vacuum leak. Really hard to diagnose with just this amount of info. Important items are outside temp. and frequincy of the problem.
Mar 02, 2010 | 2000 Volkswagen Jetta TDI
Microtek c593 monitors. Out of Range
Your Minotor not support windows 7 frequincy or resulation.please open your computer safe mode, and set monitor frequincy only 60Hz. Resulation less area .Then solve your problem.
Dec 27, 2009 | Microtek C593 15" Flat Panel LCD Monitor
RCA model 27f52ot turns on and off randomly for a few seconds eac
Best solution take the tv aparts go to the small flat control board in the front on the bottom of the bazel(the frame).U know how to soldiers?Resoldier the power switch,If same prob.occur go the tv shop for repair.Ur tv have a short prob. with the ic chip or its parts that control that little board.Here another solution take all the electronic's equipments away from the tv,that solve the same waves(radio frequincies prob.) tries that solution first,some device will turn it self on, if have same frequincies use by the other devices,just like ur Automatic garage door open will open other people garge door if their control box on top their garage don't have ramdom codes function's modjulators.
Aug 21, 2009 | RCA TruFlat 27F520T 27" TV
Two diffrent units with two diffrent frequincys . i wantto change
I hate to be the bearer of bad news but those units are fixed frequencies and cannot be changed. You either have to find a mic that matches your receiver or vice-versa. The freeway 200 series comes in 3 freqs. two of witch you have with the addition of 170.245. Maybe you can find someone who has a damaged mic but still has the receiver with the freq. that you need for your mic.
Apr 11, 2009 | Audio Technica Audio-Technica ATW-T202...
Programing
Stumbled upon a blog where someone else was looking for the same info. Somebody posted an answer and it worked!
Jul 25, 2008 | Uniden Radio Communications
SWR calibration waaay off the chart
double check your connections and your cable for shorted PL 259 connectors. Oil filled antenna! Humm Sham on you if you are using a liner! Oh and quit sniping the antenna remember the higher in frequincy the shorter the antenna and longer for lower in frequincy. So it could be just where the antenna is located some antennas work good there but a diferent one wont try another spot also make sure your in a clear area when checking SWR not your drive way next to the garage or house or other car and finaly use an external SWR meter the ones on the radio some times SUCK.
Jun 22, 2007 | Cobra 29 LTD CB Radio
Magnum S9 Base CB Radio Logo
316 people viewed this question
Top Magnum Radio Communications Experts
Jim Goldsmith
Jim Goldsmith
James Walker
James Walker
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
