blower moter turns off after a hour or so some times can run all day or turn off within a hour or so...
(More)
blower moter turns off after a hour or so some times can run all day or turn off within a hour or so . replaced motor and circuit bloard. when it shuts off it takes about 5 minutes to turn back on. and keeps doing the same thing over and over. thanks
my stove shuts off 2 minute after I turn it on there's a black wire to the left when you look at the...
(More)
my stove shuts off 2 minute after I turn it on there's a black wire to the left when you look at the back of the stove which part of the power strip does it hook up to?
Need a wiring schematic for a Frigidaire FAA051N7A1 Air Conditioner. The unit fell out the back side...
(More)
Need a wiring schematic for a Frigidaire FAA051N7A1 Air Conditioner. The unit fell out the back side of the window and the electrical cord, still firmly secured to the electrical outlet, broke the fall, but the other end of the cord pulled out of the bottom of the unit. It was a soft landing so I'm sure the unit isn't damaged, but I need to reconnect the various colored wires to the proper connections. I've got the front part of the unit disassembled (where the on/off control knob is) so all I need is a color diagram showing me which wire to plug into which connection. Please help! Thanks! ericwatts@aol.com
york mini split 07-21 this unit has power,but will not come on with the remote or manualy. when the...
(More)
YORK MINI SPLIT 07-21 This unit has power,but will not come on with the remote or manualy. When the run relay contacts is briged it runs , so it seems that it is been kept off by some interlock or the controll board is faulty. While the unit is running the run relay is energised and deenergised as a voltage is measured across the coil, but will not energise without the relay contacts being briged.The tubes on the outdoor unit also ice up after a while.Is this because the unit is running continuously without stoping.The aircon does cool very quickly.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
