Question about Nikon ProStaff Laser 440 Rangefinder
Nikon laser 440 won't read past 30 yards
Two year old laser 440 began having problems last year reading past 70 yards. Problem has become progressively worse and will now not read yardage past 30 yards. Have replaced battery and reset the unit by holding down both buttons for 30 seconds, but have had no improvement in function.
SOURCE: Nikon ProStaff Laser 440 not working
Here is the address to send your rangefinder for repairs.
  • Nikon INC.
  • 841 Apollo St. Suite 100.
  • Elsegundo, CA 90245-4721
  • Attention: Repair Department
  • Phone (800) 645-6678.
I had the same issue with my Nikon Laser 800 rangefinder. I sent it in and they wanted $311.00 to fix it so I bought a new one for $300.00 off EBAY. Today I was missing around with my old rangefinder and noticed after I put the battery in I could hear something loose in the rangefinder. There is a little metal tang in the bottom where the battery goes that holds tension on the battery that was bent down. I bent it back up about 3/16" and put the battery back in, now it works fine.
Posted on Mar 13, 2008
SOURCE: Bushnell Laser Range Finder
you have it on the meters setting not the yards setting. hold the scan button down for three seconds or longer and it will revert to the other form. a meter is nearly 10% longer than a yard.
Posted on May 06, 2009
  • 115 Answers
SOURCE: Can my bushnell yardage pro rangefinder be
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Posted on Oct 06, 2009
  • 115 Answers
SOURCE: Yardage is not showing
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Posted on Mar 24, 2010
SOURCE: Nikon laser 500G range finder I can not get reads above 30 or 50
On my laser 500 G I held both buttons down together for a short time and it began reading again. See if that works with yours.
Posted on Aug 06, 2010
My toyo L-30 reads the temp then Lo for instance it currently reads 70 Lo. What does this mean?
Lo is displayed when the room temperature is below 14F or the heater thinks the room is below 14F, which would be caused by a problem with the room temperature sensor or the sensor is unplugged. 70 is what you have the heater set to maintain. Check the white wire on back of the heater.
Dec 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Jul 28, 2010 | Nikon 7431 LaserCaddy Rangefinder
Measurement is off approx. 4' to 5'. Any way to re-calibrate to have accurate measurements?
I didn't find the Prostaff laser 440 rangefinder on the website for Nikon.com, but I did find the 550 model. The specs follow:
Specifications
  • Measurement Range 11-550 yds
  • Increment Reading 0.5/1 yds
  • Magnification 6x
  • Angular Field of View (Real)
  • Angular Field of View (Apparent) 34.9°
  • Viewfinder Display meters/yards
  • Eye Relief 18mm
  • Diopter Adjustment +/-4°
  • Power Source 1 CR2 Lithium Battery
  • Size (Length x Width x Height) 5.1 x 1.5 x 2.7 in
  • Weight w/o Batteries 6.3 oz
  • Objective Diameter 21mm
  • Exit Pupil 3.5mm
  • Supplied Accessories CR2 lithium battery.
I did not read that there is a recalibration for the unit, although a consumer might expect that. Has it ever been dropped to your knowledge?
http://nikon.com/products/sportoptics/support/index.htm
The above link has contact information for service of the unit via telephone numbers.
Jul 23, 2010 | Nikon ProStaff Laser 440 Rangefinder
What should a 2002 Pontiac Bonneville oil pressure gage read at
at what? depending on engine temp and rpm, normal oil psi should read 30-40 psi at idle and at cruising speed of 1500 to 2000 rpm should read 60-70 psi. most bonnevilles from 1992 to the last year run of 2005 have the 3.8 liter V6 which was updated over the years.
Oct 13, 2009 | 2002 Pontiac Bonneville
I have a Nikon rangefinder 350G. I bought it last year. I find the reading is getting less sensitive comparing when it was brand new. It is hard to get reading when it is as far as 120 yards and more....
Push mode and power button together and hold down for 30 seconds to reset before you send it in for alignment repair. The reset might work and save you $$$.
Jul 12, 2009 | Optics
Won't range even after reset
Well after going through the reset procedure (holding both buttons down for 30 seconds) the unit didn't appear to be working. Being somewhat new to the proper use of this device it appears that it might be sensitive to low light conditions or certain objects. After playing with it more I'm now able to get it to work but there are still certain conditions where it won't give me a reading.
Feb 12, 2009 | Nikon ProStaff Laser 440 Rangefinder
Nikon 440 pro staff range finder wont read distance
I just got mine to work. It was doing the same thing. I guess I re-set it. I figured there had to be some way to re-set it. So I pushed the mode button and the power button simultaneously for 30 second. Then it worked! Wooptidoo :)
Nov 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Nikon ProStaff Laser 440 Rangefinder Logo
172 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
