Question about Sub-Zero Bottom Freezer Refrigerator
Our Refrigerator has water build up on the floor of it. There are evaporators, and drain heaters and such. Could it be any of these? The floor is in good shaped and not rusted out.
    Scholar:
  • 150 Answers
Look for a condensation collection shelf leading to a drain outlet. This could be blocked. Clear gently with a long wooden match, cocktail stick or similar
Posted on Dec 23, 2009
I have a firgidaire FRT21C5A refrigerator / freezer. I am getting a large amount of water building up in the bottom of the refrigerator below the crisper drawers. Could a condensater tube be clogged? If...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
May 31, 2011 | Frigidaire Refrigerators
Fridge is leaking water from the inside, on the back wall
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Water leak self defrosting
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My refrigerator has a leak and builds up water in the bottom. I can see that the water is coming from two square holes in the top that look like they lead to the freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Mar 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a side by side Whirlpool refrigerator. It is about 6 yrs old. It has recently started having ice build on the floor of the freezer. Any idea for a fix on this problem?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Dec 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Oct 11, 2009 | Freezers
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cooling. Refrigerator colloing on 10 setting only
Sep 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Water leaking/freezing in bottom of freezer
Jul 12, 2009 | KitchenAid KSRA25ILWH / KSRA25ILBT /...
Sub-Zero Bottom Freezer Refrigerator Logo
151 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
