Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
UZltimate care II washer pauses for a long time between cycles
My top load ultimate care II washer pauses for a very long time at the rinse cycle. How can this be fixed
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Posted on Jun 27, 2009
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Extra rinse cycle
Press the button and you will get an extra rinse cycle at the end of a normal rinse cycle. A B C
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II GSQ9669LGO
Sounds like you may need to replace the timmer
Jun 06, 2006 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
