About connecting two pc's
Hi i want to connect my two pc's. i purchased one lan cable.but i am getting confuse.because i don't where i insert that in my pc's. what i do.
    Brigadier General:
  • 7,191 Answers
Read this article on connecting two PCs. Hope it helps you. Be careful while connecting the PCs or it can lead to serious damage to PCs. Best of luck.
http://compnetworking.about.com/od/homenetworking/a/connecttwocomp.htm
Posted on Jun 27, 2009
My modem can not detect my lan card, i am using presario v3000, what maybe problem?
Greetings - I think you're not clear about how using the Internet works (not many people are - especially starting out).
The modem and the LAN card are TWO DIFFERENT ways of connecting to the Internet. The modem uses a regular phone line and the LAN card uses Ethernet (a different faster way of connecting to the Internet in which needs further hardware such as a cable or DSL modem from your ISP).
Or is it possible you're talking about connecting your LAN card to your cable or DSL modem?
If this is confusing to you please call the tech support of your Internet service provider and they should be able to walk you through getting connected..
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 17, 2011 | Computers & Internet
I want to connect a new HP laptop to my LAN. There is/was a laptop using my internet connection via a router which is still active (router) but the old HP laptop died.
In the control panel network setting, connect using 'connect to a workplace'. Ofcourse with a LAN cable, insert one end of the cable to the pc as well as the other to the router. Put in the usual parameters.
Mar 03, 2010 | HP Computers & Internet
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cannot view my client in handycafe
Check if the LAN cables are connected properly, make sure that client PC's have handycafe client installed and connected to the hub/switch with the server PC.
In some cases wherein the server has two LAN Cards installed, make sure to choose the LAN Card which is connected to the hub/switch where the client PC's are also connected during the initial start-up of the Handycafe software.
Note: Check if the hub/switch or router (whichever you're using) does not have a problem.
Nov 05, 2009 | Computers & Internet
XP Keeps rebooting with LAN Cable connected
Have you tried going into the bios setup before windows loads up? You may have a setting to choose startup on lan. Just turn that off and hit F10 and enter.
To enter the bios setup keep pressing delete after truning on the computer until the bios screen appears. Don`t change anything unless you know what you are doing.
May 14, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Due to the power fluctuation my dell laptop 1501 inspron's lan port or network adapter has been burned so whenever i insert network cable in it. it show the message of network cable unplugged
Most laptop lan ports are onboard so replacement would mean replacement of the entire Motherboard. A very costly option. I suggest buying a USB to NIC adapter from your local PC store and just use that for LAN connections.
(side note: get a good brand, cheap USB to NIC/LAN converters sometimes drop connections randomly so spend a few extra $$$ for a good one)
Apr 20, 2009 | Computers & Internet
EI System 4411 Laptop
go to the control panel, internet options, connections tab, then check mark "never dial a connection".
then try to connect.
Sep 27, 2008 | Computers & Internet
Problems
Yes, you've got a "broadband" router... won't help much with dial up..
Sep 22, 2008 | Linksys Wireless-G WRT54G Router
Laptop Internet Connection
The LAN pc card on you laptop is not recognizing the connection to the router that's why you are getting an erro saying cable is unpluggged. Try to user a different ethernet cable or try the laptop to the modem check if you will still get the same error so that we'll know if its a fault with the lan card or if it's just with the cable.
Jun 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
