Question about Samsung Digimax L70 Digital Camera
Hello, I lost my charger so I bought a DTC-5101 Li-Ion battery pack charger. But after charging (green led) and replacing the battery my digimax L70 camera gives a black screen, beeps 3 times and turnes off again. Please help me, I'm going on vacation soon and I really want to take my camera with me.
advance
  • 107 Answers
SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Posted on Feb 27, 2007
  • 76 Answers
SOURCE: Digimax A503 will not turn on
If there is a reset button on the camera try this before bringing back to shop
Posted on May 13, 2007
jackboy
  • 2985 Answers
SOURCE: I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Posted on May 25, 2007
SOURCE: advent camera battery charger
thank you i now have a charger on the way for a rollei dp4200,dp2500 im gonna try iy on my adv1172e..i hope it works! cheers!
Posted on Jun 15, 2008
wicabuss
  • 48 Answers
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Posted on May 01, 2009
WORX BATTERY CHARGER. when i PUT THE CHARGER ON THE GREEN LIGHT COMES ON.
Mike, The red LED is suppose to be on when you insert battery, the LED will go green when battery is charged. Look in your manual, Pg. 11 charging instructions. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/7/72bd8a7a-cf98-43d4-92b7-a15bc78eb6bb.pdf
Battery Driven String Trimmers
How to Check Li ion Battery
Jul 15, 2016 | Worx Gt Wg151.5 18v Cordless Electric...
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 | Drills
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Jul 15, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Samsung Digimax L70 Digital Camera Logo
243 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
