Question about Nokia N70 Cellular Phone
N 73 Simnot valid
I try to flash N73 during flash pc restart after that i flash again but can,t power on so i erase flash with erase files and flash the phone phone on but imei 1234565432? i write rpl backup do i save first rpl write ok imei ok when i insert sim phone ask sim card not valid :( so strange for me because customer on head
when i write Pm backup do i save first before flash,
Powering the phone...
Writing PM...
Field: 308, Record: 1, Len: 4096 -> OK
Done!
But after that set not on when try to on only blu screen and goes off
(again erase and flash then same)
whats wrong
when try to write pm i got this error
Checking for local SX card...
Trying to use SX4 server...
Server say: Hello!
Login...
Detected P-KEY: 900085C2
Server say: Login OK, you are number 1 in the queue, you must wait aprox. 0 seconds...
Connecting to phone...
Error receiving data from server step2...
what can i do for this problem.........:(
i have big problem with my customer if have any advice then please share.
Thanks in advance
My nokia n73 phone memory gets full without loading any files or software's and i even tried formating it by pressing *#7370# but it is occuring again n again what can i do for this
The last thing you need to do is to flash the phone.So contact mobile repairing shop or Click here1.if you want to do it by yourself.And for your flash file N73 files./ N73 file.I could not give you the right file because the are different types of N73.Good luck
Oct 14, 2011 | Cell Phones
I want to fully flash ma n73. how???
If you want to do it yourself this is the instruction.But beware of bad usb cable.First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file or N73 files and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gifInside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 15, 2011 | Nokia N73 Cellular Phone
Please i will restart my N73 phone by factory setting?
Try these:
1.- Basic Reset or Soft Reset This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) or applications from
a third party. Key Code *#7780# (click this combination of keys on the
keyboard in the mobile)
2.- Total Reset or Hard Reset This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
Hope this helps.
Ray
Mar 03, 2011 | Nokia N73 Cellular Phone
NOKIA N-73 MADE IN CHINA AFTER INSERTING SIM CARD RESTARTS
plz solve my prob my n 73 accpect any sim if accpect **** give no signal
Apr 24, 2009 | Nokia N73 Cellular Phone
Nokia n 73 dad
try this. If it did not work, then you need an actual repair place to flash the phone for you.
with the battery out, connect your phone to the computer. Then put in the battery and then the charger. Then press the power button for a few seconds. See if your computer recongnizes the phone. If it does start the Nokia software updater and try to reflash your phone. Good Luck..
Mar 18, 2009 | Nokia N73 Cellular Phone
How to format Nokia N73 Cellular Phone. Please
To format N 73 Cellular Phone Steps are shown below
  1. You can remove the mmc but keep the sim card and restart your phone.
  2. Then press the keys *#7370#.
  3. The phone would ask a confirmation.
  4. Select yes.
  5. Then it will ask for a code.
  6. Type the phone lock code (the default code is 12345).
  7. There you are! your phone will restart with all the phone memory formatted.
Tips
  • Also remember that you can reset your phone but not loose any of your personal files (I.E restore the settings that came when you bought the phone while keeping contacts etc) by following the above procedure but using the code *#7780#
Warnings
  • Don't apply these steps if you are not sure what you are doing.
  • Make sure you have enough battery power before beginning this procedure.
  • Formatting will erase all your contacts/messages, so make a backup of your phone before formatting.
  • If have MMC-card make a backup on mmcstore file !
Mar 06, 2009 | Nokia N73 Cellular Phone
My nokia N73 have problem After I press switch on button phone start but after 10 second it will switch off and then swicth again then on automatically. It repeat and repeat and repeats again.
You have to format your phone.
  4. Select yes.
Tips
Warnings
Mar 03, 2009 | Nokia N73 Cellular Phone
N 73 Stuck.
If you could not complete your firmware installation,Please re install your phone with the same firmware using Nokia Software updater.
Feb 13, 2009 | Nokia N73 Cellular Phone
Turn off during software update
sir, i updated my Nokia N73 software but its shut off its self and can't turn on again...
Apr 29, 2008 | Nokia N73 Cellular Phone
Nokia N70 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
