Washer fills with water, does agitation and then it stops. If I move the knob to get it to go into a spin cycle so the water drains out, I hear a ticking noise at the knob like its trying to do something.
  • tkennedy714 Jun 27, 2009
    I went out an got a new lid switch, it did not work. The only thing that happens is when I push on the lid switch, I hear ticking in the pull/start knob.
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Posted on Jun 27, 2009
  • Jeff Rockwell
    Jeff Rockwell Jun 27, 2009
    Unless you've purchased a defective lid switch (it happens), or installed it incorrectly, the only other items that I know of that can cause similar symptoms are a defective drive motor that seizes up after it has been running. That would mean it would coincidentally stop at the same point in the wash cycle each time (it's possible, I guess). Or, the timer could also be bad. The timer has a series of wafer switches that make contact at various points during the wash cycle. Sometimes these wafers corrode and don't make contact. They can be cleaned with some fine grit sand paper, or an emory board. Some timers can be taken apart to do this, some can't. I would recommend checking you lid switch again. Let me know if this helps you.
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
GE washer does not agitate. Water does not stop filling.
If it does not agitate at all, then it is either the motor, the clutch/motor control or the agitator.
If the machine start agitating only when you advance manually the control knob, and at the same time is overfilling, that is probably because of the problem with the water inlet valve, or the water level switch, and that is also cusing the cycle to stop.
See:It's overfilling
Nov 20, 2008 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Washing Machines Logo
    61 people viewed this question
    Top Washing Machines Experts
